ls/vtec turbo questions...
New User
I have a totaled out gsr sitting in my driveway that was hit in the rear. I was told that i can have my head swapped on and my car re-wired with the gsr harness for a trade for the block of the motor, which im going to do. But i am going to need new pistons correct? what about rods too? I have je pistons and crower rods in my ls block right now but i was told they dont work with the vtec head. If so what pistons should i get for the ls/vtec turbo setup i am going to have. I am hoping to boost up to 15 lbs once i get hondata installed. I know i am going to need bigger injectors than what i have now but what else am i going to have to buy in order for this to be completed correctly? Let me know, thanks!
New User
Re: ls/vtec turbo questions... (EF9_SiR)
1. to have vtec 2. pistons can change that 3. ls/vtec turbo everyone is predjudiced against for some reason but they pull off excellent numbers 4. my block is built already and i really dont need to go EVERYTHING all over again 5. save what money?
Re: ls/vtec turbo questions... (chuckd05)
You might not need new pistons. How large are the valve reliefs in the JE pistons you are running in your LS block?
Sounds like a good deal to me. Go for it.
