oil pump questions!
Old Feb 11, 2003 | 12:48 PM
boostin b16's Avatar
Default oil pump questions!
i am doing a build up on my b16a2 motor...resleeving pistons/rods/custom crank/ballancing and blueprinting/ect.
but my question is... will a type-r oil pump and screen fit in the b16 motor that came with a 99-00 civic si?
and will that oil pump flow better than the stock oil pump? i plan or replacing the oil pump anyway but i was looking of an oem replacement that may give me just a little more oiling capabilities than stock, without going to a prodrive oil pump gear.(i have heard a few horror stories about them)
thanks
boostin'
Old Feb 11, 2003 | 01:01 PM
b18bturbo's Avatar
Default Re: oil pump questions! (boostin b16)
b16a oilpump that is in your car is same exact as the type R... stick with a VTEC pump gsr/si/type r
Old Feb 11, 2003 | 01:13 PM
Default Re: oil pump questions! (b18bturbo)
thanks for the advise!!
so you are saying don't go with the prodrive, stay with the oem pump?
Old Feb 11, 2003 | 01:22 PM
b18bturbo's Avatar
OEM all the way... dont get prodrive waste .. i would only go for dry sump or wet sump as a alternattive.
Old Feb 11, 2003 | 01:25 PM
MotorMatrix.com's Avatar
I am a bad person
the stock cast gear cannot be as strong as the prodrive. i mean if you have the money get it !!!
Old Feb 11, 2003 | 01:27 PM
b18bturbo's Avatar
Default Re: oil pump questions! (MotorMatrix.com)
mike you havent seen them explode on you .. not pretty.
Old Feb 11, 2003 | 01:50 PM
I am a bad person
true, but dont the stock ones shatter also??
Old Feb 11, 2003 | 08:30 PM
tony1's Avatar
food for thought, we're running a 2 stage dry sump system with the stock pump still being used for the pumping... Stock pumps aren't as bad as people think they are. Oil pump problems usually stem from another problem elsewhere...
Old Feb 11, 2003 | 08:31 PM
TurboTegB18c's Avatar
Default Re: oil pump questions! (tony1)
Great info tony.
Old Feb 11, 2003 | 08:40 PM
I am a bad person
what oil pump gear in the stock pump??
Old Feb 11, 2003 | 08:45 PM
boostaholic's Avatar
I thought the gsr/itr/b20 oil pumps were different from the b16a? Can you confirm this?
Old Feb 11, 2003 | 08:51 PM
tony1's Avatar
STOCK!
Old Feb 11, 2003 | 08:54 PM
I am a bad person
oh well mine is prodive and I spent too much on it to pull it out. it has worked so far.
Old Feb 12, 2003 | 06:00 AM
Bnjmn's Avatar
It seems like for the Prodrive (or Toda) to fail there would have to be an install problem- not clearancing the pump, not running a pulley damper, not getting the bottom end balanced, etc.
The circumstances surrounding any of these oil pump failures are just as important as the failure itself.
Old Feb 12, 2003 | 07:46 AM
b18bturbo's Avatar
Default Re: oil pump questions! (Bnjmn)
highly agreed. The problem is people just except it to drop in with no perfect clearance it not always the case...
Dry sump is the way to go like tony said.
Old Feb 12, 2003 | 08:44 AM
CHEETAH's Avatar
Viren and Tony, you guys never tried the Toda gears ? I use them all the time and really like it ... hell I boosted with them for 4 yrs using the undampened pulley ... although I got away with murder back then, I'm sure the stock would ahve caved durint that period. The toda material is very strong too and clearance ar always 100% within spec for the 20 or so I've installed in people's cars.
btw, I think spoon use those in their motors too ... they get them from Toda ... along with all the other stuff.
[ee] or maybe its different for you two crazy boys that boost a gazzillion psi boost on them motors ... hackers !!!
LOL
Greg
[Modified by CHEETAH, 5:45 PM 2/12/2003]
Old Feb 12, 2003 | 08:58 AM
Bnjmn's Avatar
and how much does dry sump cost?
Old Feb 12, 2003 | 02:33 PM
Full-Race Geoff's Avatar
Default Re: oil pump questions! (CHEETAH)
toda is same material as stock, just thicker to fill the cavity and push more volume.
Old Feb 12, 2003 | 02:44 PM
GZERO's Avatar
Or what would you need? i think the things are:
Oil pan
Oil reservoir
lines?
fastdohc
May 25, 2011 07:43 PM
mahatma
May 4, 2006 08:38 PM
2uy
Oct 23, 2005 09:56 AM
sk8rmike
Sep 9, 2003 09:27 PM
