Maximum boost with wastegate spring and boost controller...
Old Feb 10, 2003 | 08:05 PM
BoostedSi's Avatar
Default Maximum boost with wastegate spring and boost controller...
I took apart my Tial and I thought I ordered the .65 bar but my spring is yellow which is the .45 bar I believe. I have a Hallman MBC and I just wanted to know how high I will be able to boost?
Old Feb 10, 2003 | 09:03 PM
T-sohctec's Avatar
Default Re: Maximum boost with wastegate spring and boost controller... (BoostedSi)
W H A T T H E F U C K ?
Old Feb 10, 2003 | 09:59 PM
BoostedSi's Avatar
Default Re: Maximum boost with wastegate spring and boost controller... (T-sohctec)
uhh...and that would be how much boost converted to psi?
Old Feb 10, 2003 | 10:48 PM
GZERO's Avatar
can remember 14.7 or 14.5 (cuz i can't seem to remember after that debate)
14.5X.65= 9.4 psi
14.5X.45= 6.5 psi
Old Feb 10, 2003 | 10:57 PM
IntegD's Avatar
New User
Default Re: Maximum boost with wastegate spring and boost controller... (GZERO)
No no no..I think you are missing the question.(It was me that posted under boostedsi's name) I have a manual boost controller. I have a .45 bar tial wastegate. Now, with my manual boost contoller, can I run a gazillion psi, or does the spring limit me?? For example, the maximum a .45 bar spring could go is like 15 psi, and the maximum a .65 bar spring could go would be like 22 psi. Basically, since I have a boost controller, can I run however much boost I want or does that spring limit me to a certain amount?
Old Feb 11, 2003 | 07:29 AM
MikeMAN's Avatar
Default Re: Maximum boost with wastegate spring and boost controller... (IntegD)
.45 bar = 6.5psi
.65 bar = 9.4psi
i believe you are limited to boost at whatever spring u are using, as the wastegate bleeds off excess boost so u don't Overboost.
Hope that helps!
Mike
p.s. someone correct me if im wrong
Old Feb 11, 2003 | 07:33 AM
ykracing's Avatar
Default Re: Maximum boost with wastegate spring and boost controller... (MikeMAN)
yes, you can basically run as much boost as you want, the boost controller will 'override' the spring in the wastegate...... (at least thats how most of them work)
you just cant run any LESS boost than what your wastegate spring is rated for.
Obviously, you want to be conservative on the amout of boost you run, according to what your motor can handle.
Old Feb 11, 2003 | 09:05 AM
IntegD's Avatar
New User
Default Re: Maximum boost with wastegate spring and boost controller... (trboCIVIC&WRX)
Thanks...I thought it was something like that...I just didnt know the exact limits. If anyone else wants to chime in ...sweet.
Old Feb 11, 2003 | 09:59 AM
ill_take_one's Avatar
I heard you should only boost about double what the spring can hold. Can anyone verify this statement??
Thanks
Old Feb 11, 2003 | 10:08 AM
BoostedSi's Avatar
Default Re: Maximum boost with wastegate spring and boost controller... (ill_take_one)
I know i boosted 17psi on my 7psi spring with the profec b **** at 3 o'clock. i had another quarter that i could've turned...maybe like 20-22psi max.
Sketch_hs
Aug 5, 2004 10:10 PM
Taikonaut
Oct 29, 2003 11:34 AM
yusoslo
Jul 12, 2003 08:01 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
DIRep972
Aug 18, 2001 03:34 AM
