Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS
Old Feb 10, 2003 | 10:37 PM
Full-Race Geoff's Avatar
Default Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS
hey art can you make this a sticky?
For my senior engineering lab, i am going to (along with 8 other senior mechanical engineering students) be putting a number of manifolds through a variety of tests.
I would like to test as many B series manifolds as possible. The tests will go on during the last week of april and i will need anyone who is able to let me use their manifolds in this test. Revhard, DRAG, Maxrev, no full-race tho and anythign else you might have.
We will test for pressure drops, air flow equivalencies, frictional flow through a pipe, frictional effects of air in various collector arrangements, etc.
The manifolds will not be damaged in any way during the testing, and if you need references, ask the majority of the people on this board. I will post the manifolds i dont need as we receive the samples. Any manifold manufacturers are welcomed to sned their products, and i assure you the data will be unbiased.
Thanks
Old Feb 10, 2003 | 11:08 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS (FFgeoff)
I have a inlinePRO I can donate.
Old Feb 11, 2003 | 06:02 AM
tony1's Avatar
Default Re: Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS (Arturbo)
I've got cast rev hards, meng, and short runner tubular rev hards. I'll rent them to you. j/k
Old Feb 11, 2003 | 10:28 AM
Default Re: Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS (tony1)
ok you guys will be getting phone calls the first week in april
i am going to build a GIANT plenum box for which to create a high pressure region, and from here i will weld a flange that the manifolds will attach to. Then flow each one, monitor pressure drops at various air flow levels, velocities, and a host of other things. All the stuff is already in the lab so all i have to do is make the huge plenum and weld a flange to it. shouldnt be too bad.
Old Feb 11, 2003 | 10:39 AM
DeepSi's Avatar
good luck Your senior project sounds really tight. that is the way to mix school and hobby together.
Old Feb 11, 2003 | 10:43 AM
SiRkid's Avatar
that is awesome!!!
Old Feb 11, 2003 | 01:06 PM
underpressure02's Avatar
I got a stock ls Manifold. I may need references though. J/k If you still need a Drag manifold let me know. I will just borrow your off your car while you are using mine.
Old Feb 14, 2003 | 09:56 AM
bretx0r's Avatar
Default Re: Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS (underpressure02)
ill donate one, and you can keep it...
...if you give me one of your full race manifolds
Old Feb 16, 2003 | 02:58 PM
bump for a good guy
Old Feb 16, 2003 | 09:55 PM
magicwand's Avatar
I definently have a Drag you can use for a set of those really cool ls/vtec dowel pins and a report of the testing
Old Feb 27, 2003 | 07:25 AM
Bump for a good guy
Old Feb 27, 2003 | 08:09 AM
DaveF's Avatar
im interested in the outcome of the project. please post results when you are finished. thanks
Old Feb 27, 2003 | 08:13 AM
Finest's Avatar
Default Re: Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS (2.2Lcivic)
Can we send in our "custom" manifolds? Curious as to how it stands against the "name brands".
fbcfab
Apr 19, 2016 03:50 PM
BMCRace
May 23, 2011 04:01 AM
FlewByU352
May 26, 2010 07:57 PM
garyhgaryh
16
Sep 3, 2007 09:02 AM
