where can i get a cheap oil catch can.... i mean super cheap
Re: where can i get a cheap oil catch can.... i mean super cheap (Boosted97Lude)
soda bottle...other than that $40 is about as cheap as they come, I think Summit makes a generic one that's like the Jazz can.
What is this crap?
not a bad idea. piece of pvc and 2 caps. probly $6 for the real nice threaded parts at Lowes. $3 if you pvc cement it.
Guest
Posts: n/a
Re: where can i get a cheap oil catch can.... i mean super cheap (falconGSR)
[Modified by Boosted97Lude, 11:24 AM 2/13/2003]
Re: where can i get a cheap oil catch can.... i mean super cheap (Hatchblack)
The Moroso can is $35 from summit, not sure why everyone acts like that is a lot of money, especially considering how much we have all spent on our cars.
Guest
Posts: n/a
Re: where can i get a cheap oil catch can.... i mean super cheap (sharkcohen)
I actually have a plastic fuel filter inline between the valvecover and IM on my B20. It works quite well actually. I have pics, but nowhere to host them. $1.99, replaceable. simple.
It depends on WHY do you need a catch can? If you simply want to prevent oil from entering the IM and release crankcase pressure, just go do a open loop. It costs nothing more than a length of hose, which you will need anyway regardless with method (open or close loop) to use.
Guest
Posts: n/a
Re: where can i get a cheap oil catch can.... i mean super cheap (JT)
I don't remember the Moroso can being only $35... This $68 one is what most people use. http://store.summitracing.com/global.../mor-85470.jpg . This is a good can which comes with a baffle that most other catch cans dont.
Re: where can i get a cheap oil catch can.... i mean super cheap (JalopySiR)
Re: where can i get a cheap oil catch can.... i mean super cheap (mos)
Seriously, just go down to your local ricers r' us and look at the fuel filters. They all have at least an inlet and an outlet. They are compact. They are cheap. They are replaceable. They work.
Guest
Posts: n/a
check it out guys, this is my catchcan i just made from parts at my Dad's Hardware store, it's a 6" peice of 1.25" PVC pipe with a cap on either end and a couple of hose repair nipples. i decided to paint it "Ford Dark Blue" to match the color i painted my engine.... all in all, i think i spent about 5 bux
[Modified by Boosted97Lude, 11:10 AM 2/15/2003]
Does this unit have a drain, or is this just going to be temporary. It looks too nice to be temporary...
so the catch can is connected to the valve cover thing on one side and where does the other side go to?
Guest
Posts: n/a
Re: where can i get a cheap oil catch can.... i mean super cheap (quikrpm'z)
ive been thinking of doing one like this my self. Did u use screw caps or did u glue them on? How did u create a baffle for it.
Guest
Posts: n/a
Re: where can i get a cheap oil catch can.... i mean super cheap (Sonny)
there is no vent, for where i need it on my H22, there is a direct hose that goes from the valve cover to the intake manifold
as for the the other nipple on the valve cover, like on the B series, i have a small K&N style filter on it.
