do you really need a BOV
Old Feb 12, 2003 | 09:18 AM
nortel's Avatar
Default do you really need a BOV
is it really vital to have a BOV when running low boost (10 pounds or less) or is it just for that ricer effect?
Old Feb 12, 2003 | 09:53 AM
ill_take_one's Avatar
Default Re: do you really need a BOV (nortel)
Did you do a search?
Yes, you need one, unless you love the sound of compressor surge.
Do you want your turbo to last, or take a **** on you?
Peace
Old Feb 12, 2003 | 11:45 AM
NCSTIdriver's Avatar
First time i've ever heard a bov on an actual turbo called a rice effect. you have much to learn man.
Old Feb 12, 2003 | 11:49 AM
camp1320.com's Avatar
Default Re: do you really need a BOV (NCH22driver)
Take it easy guys.. this is what H-T is about helping the people in need and educating the less knowlegable.. YES it would be smart to get even a cheap BOV.. they run from $99-$300 which is not alot of money. and there are many to chose from
Old Feb 12, 2003 | 11:53 AM
Default Re: do you really need a BOV (camp1320.com)
My bad, but i dont think i was that hard on him.
This subject has been covered a MILLION times. Thats what the search button is for
Old Feb 12, 2003 | 12:29 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: do you really need a BOV (ill_take_one)
FYI, a LOT of stock turbo cars DO NOT have BOVs, my first Zcar, before any modifications had only a 'pop-off" valve to relieve the pressure during a catastrophic boost surges. my first mod? welding it shut and raising boost to 10PSI.
stan
Old Feb 12, 2003 | 12:31 PM
Full-Race Javier's Avatar
is ur car auto?
Old Feb 12, 2003 | 12:42 PM
Default Re: do you really need a BOV (90crxsi)
yes FYI alot of the older turbo cars did not have a BOV... but the newer cars like the eclipse from 1990-1998 some some others did come with some kinda of BOV.
Old Feb 12, 2003 | 01:37 PM
ITR981002's Avatar
BOVs from first Gen DSMs work great if money is kinda tight. You can usually pick them up for $35-50 with the flange that you'll need to weld to the IC pipe.
You can look for one here: http://www.dsmtrader.com
Old Feb 12, 2003 | 04:10 PM
spooled b16's Avatar
Default Re: do you really need a BOV (gothatch)
you can get a plastic bosch for 30$ at shucks ask for a saab over pressure release valve. Their super quiet and good for 12lbs.
Old Feb 13, 2003 | 10:45 AM
nortel's Avatar
Default Re: do you really need a BOV (spooled b16)
thanks for the help, i am still learning every day. that is what this site is for right?
Old Feb 13, 2003 | 10:56 AM
swlabhot's Avatar
Peace
Chill dude... Don't forget we ALL started off with no or limited knowledge on this subject sometime in the past.
Old Feb 13, 2003 | 11:01 AM
Suprdave's Avatar
Default Re: do you really need a BOV (swlabhot)
I'm selling a polished 1G BOV, for $75....
PM me. Comes with the pipe and everything.
Suprdave
Old Feb 13, 2003 | 11:02 AM
ninesecrx's Avatar
Actually I dont think you really need a bov. Turbo charging has been around for a long time now. Bov's are recent addition to the market. Some feel its just anouther gimic or part to sell and make money. When you shift and let off the gas, the air will go back, but when you crack the throttle open the surge will stop right away as gasses hit the turbine wheel. Personaly id say run a bov, but I really dont think its needed.
Old Feb 13, 2003 | 11:21 AM
Default Re: do you really need a BOV (ninesecrx)
Yes turbocharging has been around for a LONG time . but that was then and this is now. Technonlogy has stepped in and inventors not only trying to make $$$$ but have created some kind of gimic or parts to better and lenghten the life of any turbo or motor itself.Denpending on how much boost you are running. It is a DEFINTE MUST.. has anyone put there hand in front of a bov at 9 psi, reving the motor at no LOAD. there a a heavy force of air that would usally surge back to the turbo.some times even pipes pop off at higher number of boosting.I have persoanlly seen throttle bodie butter flys bend on certain cars. imagine on load at 7000-8000RPM.I would pay $50-200 on a BOV and it also comes with some cool noise then to spend $$$ rebuilding motors and turbos.
Old Feb 17, 2003 | 01:26 AM
Built_For_Boost's Avatar
bump camp1320
Old Feb 17, 2003 | 06:12 AM
turbopanda's Avatar
Default Re: do you really need a BOV (Built_For_Boost)
Compressor surge actually sounds better than a blow-off valve u know.. (seriously!!) - its twice as loud as any blow-off i've ever heard.. and for those of you wondering what it sounds like.. just imagine a Greddy Type-R blow-off valve, releasing 1.2 bar of boost, but cooler sounding
Old Feb 17, 2003 | 06:44 AM
mamaboy's Avatar
1G DSM bov should do the trick and it's fairly cheap.
Old Feb 17, 2003 | 06:51 AM
thenick's Avatar
Default Re: do you really need a BOV (mamaboy)
function over form. dont be fooled by all the bling whoosh BOV's
Old Feb 17, 2003 | 07:40 AM
nortel's Avatar
Default Re: do you really need a BOV (turbopanda)
i am with you, i actually like the sound of compressor surge, but i guess it is probably bad for the turbo.
Old Feb 17, 2003 | 07:41 AM
nortel's Avatar
Default Re: do you really need a BOV (Suprdave)
Suprdave
i just found out i dont have permission to use pm????? i hate being a noob
Old Feb 17, 2003 | 07:46 AM
ekb18c's Avatar
Get yourself a Tial Bov and call it a day! Better safe then sorry !
Old Feb 17, 2003 | 07:50 AM
nortel's Avatar
Default Re: do you really need a BOV (ekb18c)
why tial?
Old Feb 17, 2003 | 10:50 AM
why tial?
It's a quality piece
Old Feb 17, 2003 | 10:58 AM
zojirushi's Avatar
dsm bov's are great... i use one
