GReddy Turbo Kit install problem
Old Feb 13, 2003 | 12:40 PM
Yamzz_EG's Avatar
Default GReddy Turbo Kit install problem
Ok so my friend and i were putting in my GReddy Turbo Kit on my D16z6 hatch, it was all going good until we hit a little problem. Where the Charge tube hooks up w/ the turbo and where the oil return line hooks up to the turbo are very close together and we cannot fit both of them on. I am confused on what to do, did anyone else encounter this problem? Does anyone have any ideas? thanks in advance.
Old Feb 13, 2003 | 05:15 PM
boostedel's Avatar
Default Re: GReddy Turbo Kit install problem (Yamzz_EG)
mine ended up being a tight fit, not too sure if anyone else experienced the same thing
Old Feb 13, 2003 | 05:35 PM
turboD16's Avatar
yeah same here..you can just clock the turbo a bit, but im sure if you play with it, you can manage it to fit
Old Feb 13, 2003 | 06:19 PM
romeo619romeo's Avatar
Default Re: GReddy Turbo Kit install problem (turboD16)
mine wasnt hard at all... try putting the return tap furthest to the passenger side thats what i did
Old Feb 14, 2003 | 01:36 AM
Trac226's Avatar
Default Re: GReddy Turbo Kit install problem (romeo619romeo)
Try hooking up and clamping down the oil return line first, then the charge pipe. It's a small space but it will fit nevertheless.
Old Feb 14, 2003 | 12:20 PM
Yamzz_EG's Avatar
Default Re: GReddy Turbo Kit install problem (Trac226)
thanks guys i will let you know how it turns out.
McLude2nR
Jan 18, 2007 01:25 PM
Bailhatch
Oct 22, 2003 07:53 AM
Yamzz_EG
Feb 14, 2003 12:20 PM
