Golden Eagle Mfg.
Old Feb 10, 2003 | 11:19 PM
X-Mazda 3 Racer's Avatar
Default Golden Eagle Mfg.
Here are some of our engine build quotes in phases. It is simple, the more you want, the higher the phase. These are all for B-series engines. We also have D, H, F and K builds available.
Phase 1 B16, B17, B18A/B/C
Very low boost ( under 10 psi ) All-Motor
Stock Block
Arias Pistons 81.5mm
Eagle Rods
ACL Bearings
New Factory Oil Pump
Bottom End Gasket Kit
Bore & Hone
Step Deck Resurface
Balance Rotating Assembly
Micro-polish and oil hole chamfer crank
Line Bore
Jet Wash Cleaning
Assembly
Total $2023 plus shipping
Phase 2 B16, B17, B18A/B/C
Turbo ( up to 30psi ) or All-Motor
Golden Eagle Mfg. Econo-Sleeving up to 85mm
( Econo sleeve is just like RS or any other STANDARD style open deck sleeve )
Arias Pistons
Eagle Rods
ACL Bearings
Bore & Hone
Step Deck Resurface
Line Bore
Jet Wash Cleaning
Assembly
Total $2673 plus shipping
Phase 3 B16, B17, B18A/B/C
Turbo ( up to 60 psi!!!!!!!!! ) or All-Motor
GOLDZILLA Sleeving up to 85mm <---- the best selling sleeve on the market!
Arias Pistons
Eagle Rods
ACL Bearings
Bore & Hone
Step Deck Resurface
Line Bore
Jet Wash Cleaning
Assembly
Total $2773 plus shipping
Up to 87mm add $100
Crower rods add $290
Eagle & Crower stroker cranks available
Custom BOLT-ON deck plates available from $395
Custom long rods available from Crower, Cunningham and Eagle
JE, Probe, Wiseco and Endyn Pistons available
Factory Overbored Headgaskets available $89.99 <--- the best thing ever!
ARP's available
External oil pump kits or Dry sump kits available
Golden Eagle Mfg. ADJUSTRU Cam Gears, Fuel Rails, Vtec Conversion Kits, Turbo Oil Feed Kits, Turbo Intake Manifolds, Vacuum Manifolds, Engine Mounts ( B-series into 88-91 Civic HERE, others coming very soon! ), Block Guards, Engine Storing Stands, Wire Covers, Billet Cam Seals, AN fittings, Scatter Shields available
Coming soon: Engine Dress-up Covers, Dip Sticks, Cig Lighters, Oil Caps, Electric Water Pump Kits, Rear Bumper Ports and many more new products!
Dealer Inquires Welcome!!!!!!
Please give us a call Mon - Fri 7:00 a.m. - 5:00 p.m. pst
(909) 592 - 4311
or visit out web-site at http://www.goldeneaglemfg.com <---- New Site Coming Really Soon!!!
[Modified by GoldenEagleMfg.com, 8:21 AM 2/11/2003]
Old Feb 10, 2003 | 11:22 PM
GSRrR's Avatar
Default Re: Golden Eagle Mfg. (GoldenEagleMfg.com)
60psi
Oh my.
Saving my pennies now and going on a bread and water diet.
Old Feb 10, 2003 | 11:41 PM
Kwuaymaikrup's Avatar
Default Re: Golden Eagle Mfg. (GSRrR)
Damn! Just can't stop you guys. Keep it up.
Old Feb 10, 2003 | 11:48 PM
ninesecrx's Avatar
Default Re: Golden Eagle Mfg. (Kwuaymaikrup)
Good luck getting 60 pounds out of eagle rods. Id be scared at half that boost on those rods.
[Modified by ninesecrx, 9:06 AM 2/11/2003]
Old Feb 11, 2003 | 12:03 AM
Default Re: Golden Eagle Mfg. (ninesecrx)
Me too, I wouldn't go past 15 or so pounds on the Eagle rods. It is better to just upgrade to the Crower or better in the long run!
Old Feb 11, 2003 | 12:25 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
LoL, eagle rods + 60 psi = , i wouldnt bother at all..i would upgrade to crowers without blinking right from the start
Old Feb 11, 2003 | 12:40 AM
BudaKai's Avatar
Do these engine mounts allow for the B-seies to sit in the EF chassis the right way (as in the way the JDM have them) or is it a bang the frame deal too?
Are these prices with or with-out core?
Old Feb 11, 2003 | 10:00 AM
AB16A2T's Avatar
Default Re: Golden Eagle Mfg. (BudaKai)
Up for all to see.
Old Feb 11, 2003 | 10:06 AM
gigantor's Avatar
aren't eagle rods made in china?
Old Feb 11, 2003 | 10:07 AM
genop's Avatar
Default Re: Golden Eagle Mfg. (gigantor)
are the prices for the D-series builds about the same??
Old Feb 11, 2003 | 10:26 AM
Judah's Avatar
Arias Pistons
Eagle Rods
ACL Bearings
Bore & Hone
Step Deck Resurface
Line Bore
Jet Wash Cleaning
Assembly
So, I pull the motor and take the head off and ship you guys the rest and you work your magic and send it back to me ready to put the head back on?
Old Feb 11, 2003 | 10:28 AM
BigD+Itsuki's Avatar
Default Re: Golden Eagle Mfg. (genop)
I was wondering the same thing.
Old Feb 11, 2003 | 11:06 AM
badCRX's Avatar
New User
Do you have a problem with Chinese people? j/k! I spoke with Ben at AEBS and he made the same comment to me about them and I wanted to say that, but didn't.
Old Feb 11, 2003 | 11:30 AM
Default Re: Golden Eagle Mfg. (TypeR895)
Yes, it will be ready to install the head. D-series is right around the same prices!!!
Old Feb 11, 2003 | 11:37 AM
falcongsr's Avatar
What is this crap?
Golden Eagle:
can explain the changes you've made to your installation/machining process of the Godzilla sleeves so that they dont sink anymore?
On another forum, someone from GE made some comments about machining the block differently. It was in reference to a suggestion that you machine the water jacket so there is a lip that the tang sits on so it won't try to sink.
Old Feb 11, 2003 | 11:43 AM
SpeedMonkeyRacing's Avatar
Default Re: Golden Eagle Mfg. (falconGSR)
hmmm..why do you guys don't think highly on eagle rods? I have never seen eagle rods fail on any motors yet... crower's good, but eagle's best bang for buck.
Jeff (who's running eagle rods and boosting **** load)
Old Feb 11, 2003 | 11:55 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Old Feb 11, 2003 | 12:29 PM
DD_JonnyLee's Avatar
Default Re: Golden Eagle Mfg. (vtecvoodoo)
bump.... i would also like to knoe the problems with eagles
-jonathan
Old Feb 11, 2003 | 12:32 PM
b18bturbo's Avatar
Default Re: Golden Eagle Mfg. (TrboGSR)
theres really no problems with the eagles.. they just seem weaker at high boost levels.
Old Feb 11, 2003 | 02:22 PM
TheShocker's Avatar
Default Re: Golden Eagle Mfg. (b18bturbo)
What do the econo sleeves look like? Can you explain what they are?
Old Feb 11, 2003 | 04:57 PM
blufke's Avatar
Default Re: Golden Eagle Mfg. (TheShocker)
how long would it take after you receive the block?
Old Feb 11, 2003 | 06:19 PM
94cxhybrid-T's Avatar
New User
i would also like to know this..
Old Feb 11, 2003 | 06:45 PM
shingles's Avatar
Viren,
when you say high boost, what type of levels are you taking about?
thanks,
-S
Old Feb 11, 2003 | 06:48 PM
FritzInTN's Avatar
Default Plop.
What prep work should be done to the engine? i.e. Would one just crate up a longblock and throw a few pounds of stamps on it? Or should we follow the previous guidlines of stripping it to a bare block and crating it up?
Thanks
Old Feb 11, 2003 | 06:53 PM
C-Murdock's Avatar
Default Re: Plop. (FritzInTN)
To Golden Eagle for more advertising....
What are you guys doing to prevent sleeves sinking ?
Also, this is good that you guys are finally assembling blocks and shipping them back *Ready to Install*
