boosting but not goin anywhere
Old 02-12-2003, 04:15 PM
face's Avatar
Default boosting but not goin anywhere
just did a turbo install on a h22 97 prelude and everything is hooked up right , but the car boosts but doesn't go anywhere, basiclly its slower than stock , and also it never stops boosting it got up to 10 psi and we backed off because we didn't want to blow it up .
now the boost gauge is tapped in right after the throttle body , i have heard that it should be tapped in the back of the manifold not so close to the tb
now what the hell is wrong???
Old 02-12-2003, 04:18 PM
GSRwBOOST's Avatar
Default Re: boosting but not goin anywhere (face)
do you still have a clutch??
LOL...
some people bolt the turbo on, get out of the driveway.. give it a whirl and it's gone....
are you boosting but running lean? if your boosting but it's feeling like it's sputtering and loosing power or not quite there.. maybe it's not getting enough fuel..
Old 02-12-2003, 04:20 PM
Tofurky's Avatar
whats the set up?
Old 02-12-2003, 04:32 PM
Tinker219's Avatar
Default Re: boosting but not goin anywhere (Ruckus138)
maybe your wg spring is too tough....my buddy got a deltagate with a 35psi spring! He wondered why it hit 20psi, and blew all the charge lines on the first test drive. Of course his car went somewhere though...
Old 02-12-2003, 04:52 PM
face's Avatar
Default Re: boosting but not goin anywhere (Tinker219)
ok, we dont believe that it is the waste gate cause we have tried two and it does the same thing. btw it's a deltagate.
i have a new high volume in tank fuel pump w/ fmu so it shouldn't be fuel but it's possible.
we disconnected the intake side piping and runs fine so it's not the car.
also retarding the timing?????????? we dont know how it's not like the normal distributor it's fixed in it's position and we cant turn it so the timing is stock.
please help we've had a lot of down time and are ready to get it going
Old 02-12-2003, 04:54 PM
Tinker219's Avatar
do you have anything to fool the map sensor???
Old 02-12-2003, 05:17 PM
GRT
GRT's Avatar
you need a missing link to trick you map.
Old 02-12-2003, 06:10 PM
face's Avatar
Default Re: boosting but not goin anywhere (GRT)
we are running a check valve and have not gotten a cel yet ,and if it were hooked up wrong it would definetly throw a cel
Old 02-12-2003, 06:35 PM
Tofurky's Avatar
is the fmu hooked up right?
Old 02-12-2003, 06:48 PM
face's Avatar
yes fmu is correct the upper outlet goes to the fuel rail and the lower is the return
Old 02-12-2003, 06:58 PM
easy jesus_151's Avatar
Do you have a inline fuel pump?
Old 02-12-2003, 06:59 PM
face's Avatar
Default Re: boosting but not goin anywhere (easy jesus_151)
no its a intank 255 walboro
Old 02-12-2003, 08:38 PM
BlkSIvic's Avatar
check your chargepipes, make sure they are all connected
Old 02-13-2003, 06:54 AM
Tinker219's Avatar
Default Re: boosting but not goin anywhere (BlkSIvic)
post everything that you have..manifold down to injectors...
Old 02-13-2003, 07:05 AM
StageIIIhb98's Avatar
do you have an exhaust temp guage or anything to let you know if you are lean or rich.
I had that problem when I turned the boost up too high and I slowed down compared to lower boost I ran lean and not enough fuel tuning for the boost I went to.
What is your pressure gauge set to at idle?
And yea how is your Clutch?
Old 02-13-2003, 07:07 AM
PM-Performance's Avatar
too rich? too rich = loss in power.
LedJetta
08-19-2008 08:52 AM
jdmsohc2nr
06-30-2007 09:38 PM
JayDiem_k20_Dc5
05-28-2006 09:13 AM
graphic
08-28-2003 02:37 PM
GruvyTune
10-26-2001 07:05 PM
Quick Reply: boosting but not goin anywhere
