UberTeg + OBD1 Boost Chips
Old Mar 20, 2003 | 03:48 AM
Hybrid's Avatar
Default UberTeg + OBD1 Boost Chips
UberTeg do you have a chip support a boosted sohc vtec with 450cc injectors?
So basically your chip does what? I know it adjusts for boost, but if you send me a chip with the base fuel/timming maps how do I tune? With my SMC and then send the chip back to you and you'll program my smc settings? then I can remove my smc? How does this work with the map sensor once I do remove the smc?
Old Mar 20, 2003 | 06:06 AM
Tinker219's Avatar
Default Re: UberTeg + OBD1 Boost Chips (Hybrid)
Its pretty much Hondata...nuff said
Old Mar 23, 2003 | 06:48 AM
Hybrid's Avatar
Default Re: UberTeg + OBD1 Boost Chips (Tinker219)
So I can eliminate the use of an MSD with this unit? Plus the chip controlles my timing under boost?
Bunch of questions coming:
Is the chip soldered in?
UberTeg can reprogram with with my settings, but will this work good with the smc+ and put some tunability in my own hands? Or is it better to run this unit solo?
And there are P28 chips available right.
UberTeg you need to do a write up or have a page for the chip.
Old Mar 23, 2003 | 06:55 AM
Mr. Softee's Avatar
yes. see his write up. you can take out how many degree per boost you want, he normally does 1 degree.
b18bcrxhf
Dec 9, 2006 07:25 PM
filetofit
May 27, 2004 07:50 AM
PressurizedSi
Dec 30, 2002 06:15 AM
