Quick Fuel Pump Question
Old Mar 20, 2003 | 01:22 PM
minorthreat's Avatar
Default Quick Fuel Pump Question
my civic was turbo until just recently. i got pulled over and now i have to see a smog ref. my car's all back to stock now except for the exhaust and fuel pump. I was about to change that back to stock too, but then i started thinking i probably didn't need to. will having a 255lph fuel pump on an otherwise stock car cause it to run rich? according to my a/f ratio guage (i know, i know), for what it's worth, it's right on the border of stoich and rich all the way to redline. I figure i shouldn't need to put the stock one back in because there's nothing telling my fuel pump to pump more than stock.
so bottom line: is it necessary to put the stock fuel pump back in to pass emissions testing, or at least to run clean and well?
side note: anyone been to a smog ref? how thorough are they? are they likely to notice that i have the stock intake plumbing off a gsr stuffed onto my throttle body?
thanks, guys
Old Mar 21, 2003 | 02:33 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Quick Fuel Pump Question (minorthreat)
if your fuel pressure regulator can work correctly with the bigger pump, no need to change.
But a stock FPR cannot bypass enough to control pressures to below 50 psi with a 255 LPH HP Walbro.
Old Mar 23, 2003 | 11:04 AM
RyanEJ8's Avatar
Default Re: Quick Fuel Pump Question (Mista Bone)
What fuel pressure roughly would the stock fpr run then with a 255 LPH HP Walbro?
Old Mar 23, 2003 | 11:35 AM
SJP0tato's Avatar
Default Re: Quick Fuel Pump Question (RyanCivic2000)
From what I've experienced, the stock FPR can't get any lower than about 50-53 PSI with the walbro installed.
Ryan P.
ElswickB22
Mar 6, 2014 08:04 PM
thunderboy
Jun 20, 2011 03:52 PM
aznboi_106
Jul 12, 2010 07:33 PM
blkgsr03
Jan 19, 2005 10:25 AM
echo999
Mar 8, 2003 12:35 PM
