Anyone with turbo experience....
Old Mar 23, 2003 | 10:42 AM
xcivicdx's Avatar
Default Anyone with turbo experience....
hey guys im going to be purchasing a turbo setup https://honda-tech.com/zerothread?id=433322 and need some help.... anyone know wut the spring is set at in the wastegate???
2. will i need to upgrade the fuel injectors or will my stock ones be okay??/
3. what type of fuel management unit should i get ??? smc or maybe vortech fmu with discs???
4. i need this setup to be reliable because it will be my daily driver.. any comments or help will be really appreciated... thank you
and i do have this in the turbo forum but no one responds
Old Mar 23, 2003 | 10:45 AM
allmtrSI's Avatar
Default Re: Anyone with turbo experience.... (xcivicdx)
might get better responces in forced induction. .
Old Mar 23, 2003 | 11:04 AM
V8SHME8's Avatar
1. Saabs used a solenoid to regulate the boost meaning you will just need to get a boost controller.
2. You should get bigger injectors. If you want to save money you could just run a FMU and a pump. I would suggest you get some 300cc injectors, FPR, and a bigger pump like a 190lph.
3. FMUs are good, but I would rather stay away from them. I think it is kind of a band-aid for your fuel system. Get a Apexi AFC with injectors, a pump, and a FPR.
4. I have owned a Eclipse GSX for 2 years and I drive it everyday. You are going to need to crush that BOV unless you want to recirculate it. It is not very hard to do here is a link. http://www.thedodgegarage.com/turbo_bov_mod.html. You are going to need to get intercooler piping and when you do, make sure you use T-bolt clamps unless you just want the piping to blow off. Use quality silicon connectors also as the crap rubber stuff you can get just stretches after it has been on for a week. There is no reason why the car will not be reliable as long as you run a boost level that is acceptable with the amount of fuel that you can supply. Also, it is good to see that you have a T3, in my experience with Hondas, the T3/T4 setups have a little too much lag for my taste. Good luck.
[Modified by V8SHME8, 3:06 PM 3/23/2003]
Old Mar 23, 2003 | 03:40 PM
xcivicdx's Avatar
Default Re: Anyone with turbo experience.... (V8SHME8)
so i cant just run the turbo without a boost controller?? i was told i would be able to and that it has a set spring rate somewhere from 6 to 9 is that wrong???also there is no way to run the stock injectors?? i really appreciate it..
Old Mar 24, 2003 | 03:19 AM
V8SHME8's Avatar
You can run the stock injectors with a FMU, FPR, and a pump if you would like. Personally, I would not do that cause the FMU is not that much less that injectors that would be suited to this application. You are going to just need to get a boost controller or change the spring in the wastegate that you have to whatever boost level you would like. A boost controller is the better way to go. It is gonna cost about the same if you get a manual (the best way to go) and then you have some adjustability.
honkey2fly
Apr 22, 2004 11:50 AM
yusoslo
Nov 5, 2003 08:47 PM
2k1civicturbo
Jan 23, 2003 10:43 AM
arjusmc
Sep 27, 2002 05:25 AM
