All boosted motors - plug gap
Old Mar 22, 2003 | 02:55 PM
swlabhot's Avatar
Default All boosted motors - plug gap
What are your plug gaps set at? Pls post!
Old Mar 22, 2003 | 03:06 PM
PrecisionH23a's Avatar
Default Re: All boosted motors - plug gap (swlabhot)
.028 with 15psi, usually .030-.032 is good enough on a stock ignition
Old Mar 22, 2003 | 04:29 PM
J.R.'s Avatar
Default Re: All boosted motors - plug gap (GudeH23a)
.032 b18c1 with revhard stage 2
Old Mar 23, 2003 | 09:01 AM
swlabhot's Avatar
Anyone else? Anyone stick to their stock pre-boosted gaps or increase the gap size post boost and if so by how much?
Old Mar 23, 2003 | 09:03 AM
93LSivic's Avatar
Never keep stock gap, the boost pressure "blows out" the spark. The only time you run large gaps is when you have some type of high energy spark box like the MSD 6A.
I run .030 in my LS..
Old Mar 23, 2003 | 09:11 AM
Boostfed's Avatar
New User
Default Re: All boosted motors - plug gap (93LSivic)
I run .025 with 25psi 500whp. Had to gap em close as boost was raised to keep from blowing out the spark.
Old Mar 24, 2003 | 12:49 AM
swlabhot's Avatar
Default Re: All boosted motors - plug gap (Boostfed)
OK, I can see that for highly boosted cars. The install has just been finished on my ITR and I'm only running 6lbs of boost at the moment, just until I've run it in before I increase the boost to about 10lbs.
Will stock gap of 0.044 be OK for 6lbs? I don't want the performance to be affected if I decrease the gap as I'm only on 6lbs....
No I'm not running MSD or the like to increase voltage...
[Modified by swlabhot, 4:22 PM 3/24/2003]
Old Mar 24, 2003 | 07:21 AM
swlabhot's Avatar
SOOO many boosted motors out there and no one gives a **** what their gaps are?!!?
Old Mar 24, 2003 | 07:48 AM
prophet's Avatar
5.5 psi running 8's with .28 gap....no problems so far. Idle is a bit off during warm up but afterwords its fine.
Old Mar 24, 2003 | 08:03 AM
teamrocket si's Avatar
Default Re: All boosted motors - plug gap (prophet)
.28 gap on 7-9 psi
Old Mar 24, 2003 | 08:16 AM
your question has been answered more then 10 times, what else do you want?
Old Mar 24, 2003 | 08:20 AM
TurboDANDEE's Avatar
How do you know or tell when your spark is being blow away?
im running 9 heat range .27 gap on 15 psi.
Old Mar 24, 2003 | 08:42 AM
RGAZ's Avatar
New User
0.30 with MSD, 7 series and 7 psi. I could run it at stock gap, but my plugs wear so fast, I start low and they wear down.
Randy
Old Mar 24, 2003 | 08:44 AM
RGAZ's Avatar
New User
Default Re: All boosted motors - plug gap (TurboDANDEE)
A consistent miss at high boost. Most people just keep bumping the gap down and getting colder plugs. Getting and ignition amplifier is a better solution. MSD etc.
Looks like you are already down that road.
Randy
Old Mar 24, 2003 | 08:48 AM
wickedxboi's Avatar
Default Re: All boosted motors - plug gap (RGAZ)
.030 gap on 7 series ngk running 6 psi
Old Mar 24, 2003 | 08:50 AM
GRTechnologies's Avatar
Default Re: All boosted motors - plug gap (wickedxboi)
.022 NGK 667whp
psi420's Avatar
.035 Gap, NGK BKR7E, MSD 6A, 8psi
Old Mar 24, 2003 | 08:51 AM
Flamenco-T's Avatar
Default Re: All boosted motors - plug gap (psi420)
too much gap IMO, I'd do .030 ish
Old Mar 24, 2003 | 08:57 AM
JOSEPH's Avatar
Default Re: All boosted motors - plug gap (Flamenco-T)
ngk bkr7e 0.030 gap on 8psi, stock ignition
Old Mar 24, 2003 | 08:59 AM
psi420's Avatar
I'll try that with some new plugs and see what happens.
I played with some plug gaps before the MSD, and found that I yielded the least amount of detonation on the electrode at that gap.
Since MSD went on, still saw no problems, but never bothered to lower it either.
We'll see what happens.
Old Mar 24, 2003 | 09:25 AM
Flamenco-T's Avatar
you're psi420 from honda-acura.net ? isn't the GS-R your gf's ? and you had the CRX ?
I was bheghe on the old H-A.net days...
stan
Old Mar 24, 2003 | 10:20 AM
psi420's Avatar
stan
hehe
Took the GSR off her hands, bought her an MDX, and sold the EG-h22
Some guy in Moreno Valley is enjoying Snowball, beware, she's still a sleeper turning 12's on the street.
And the GSR has had quite a bit of changes since then.
Old Mar 24, 2003 | 10:40 AM
Dublocivic's Avatar
.028@20psi
Old Mar 24, 2003 | 11:43 AM
swlabhot's Avatar
Default Re: All boosted motors - plug gap (Dublocivic)
Nice...nice...Looks like pretty much everyone here are running tight gaps. I'm not getting good # and wondering if the gap is one of the problems. However its not tuned tho and running rich as hell..
slowteg550
Jul 5, 2006 03:04 PM
turbo Si
Apr 24, 2003 08:34 PM
_Endless_
Nov 10, 2002 06:43 PM
VTC_CiViC
Jul 22, 2002 01:16 PM
swissturbo
Jun 14, 2002 11:33 PM
