How do I make a MAP diffuser w/ check valves and Ts????
Old Mar 22, 2003 | 12:57 PM
B18B EK's Avatar
Default How do I make a MAP diffuser w/ check valves and Ts????
This is the last step in my turbo install. Its a Rev Hard 2C on an LS motor. How do I construct this device? I have 5 Ts and 4 oneway valves provided by revhard. Do i block off the hole that the MAP sensor goes into on the TB? I assume you put this contraption between a boost/vac source and the nipple on the MAP sensor. right? thanks
Old Mar 22, 2003 | 01:15 PM
B18B EK's Avatar
Default Re: How do I make a MAP diffuser w/ check valves and Ts???? (B18B EK)
Also if anyone knows the website of that kid on Ebay that sells info on making turbo kits for hondas that has a diagram of the MAP diffuser. thanks
Old Mar 22, 2003 | 01:22 PM
B18B EK's Avatar
bump
Old Mar 22, 2003 | 01:26 PM
Charles B.'s Avatar
click here http://www.cse.uconn.edu/~yelevich/turbo/turbo.html and scroll down. hth.
Old Mar 22, 2003 | 02:06 PM
B18B EK's Avatar
Default Re: How do I make a MAP diffuser w/ check valves and Ts???? (SuperDuperEG)
Thanks, your the man!!! time to start it!!!
Old Mar 22, 2003 | 02:27 PM
Charles B.'s Avatar
no prob, good luck and happy boosting!
Old Mar 22, 2003 | 04:13 PM
W.Zero's Avatar
damn thats a good site
shaggyeg6si
May 15, 2008 07:48 AM
MilanoFury
Oct 22, 2004 11:15 AM
intoracing
Aug 21, 2004 03:02 PM
Mr.NiceGuy
Apr 9, 2002 02:36 PM
