Disabling the Knock Sensor - HOW!?!
Old Mar 20, 2003 | 08:47 PM
SolidSpruce's Avatar
Default Disabling the Knock Sensor - HOW!?!
hey guys, i have a fully built b16a (jap block) w/ type-r tranny, 9.8:1 JE, Crower rods, etc running w/ a p30 (jap del sol dohc vtec) ecu and plan to run 10psi daily driver once we finish fabricating my turbo manifold.
ive done alot of reading and have heard that the knock sensor can misinterpret the 'shuffling noise' generated by aftermarket pistons and predict it as ping or knock and erroneously adjusts timing. which could screw stuff up under boost.
my question is , if there is truth to this occurance (which several people have confirmed) shouldnt i disable the knock sensor? and 2 how to trick the ecu into not throwing a check engine light for lack thereof
any input on this matter is greatly appreciated.
thanks brothers
Old Mar 20, 2003 | 11:17 PM
UberTeg's Avatar
Default Re: Disabling the Knock Sensor - HOW!?! (SolidSpruce)
If your ecu is obd1, I can give you a chip for $5 + shipping that will disable knock
1.5boosted
Dec 14, 2007 01:45 PM
92ludeport
Jul 8, 2005 02:08 PM
Shft@9GSR
Sep 18, 2003 09:43 PM
untitled
Aug 8, 2003 08:03 PM
delslow94
Dec 26, 2002 12:52 PM
