how much boost should i consider running?
Old Mar 22, 2003 | 02:25 PM
[tk4L] Doke's Avatar
Default how much boost should i consider running?
how much boost would yall consider running after tunning...just wandering..im asking about the most possible with out blowing..not daily driving...
1.8l 2000 B18b
Miles on car 38000, miles on parts in motor 2500
(Rebuilt Bottom End)
Srp Pistons 8:5:1 compression
JE Pistons Rings
Crower Rods
New Rod bearings
Greddy 550cc injectors
Hondata 3 (Launch control, Full throttle shift, Shift Light, etc)
Exedy clutch
Greddy sp exhaust
Old Mar 22, 2003 | 02:58 PM
Default Re: how much boost should i consider running? (futreBoosteR)
ttt
Old Mar 22, 2003 | 03:07 PM
PrecisionH23a's Avatar
some guys on here have pushed 400+whp on stock sleeves (jinx for example), it just depend how good your tuning is. on stock sleeves personally i wouldnt go above 12psi, but thats just me...
Old Mar 22, 2003 | 03:36 PM
Adriano's Avatar
Default Re: how much boost should i consider running? (GudeH23a)
15lbs with good tuning should be fine
Old Mar 22, 2003 | 09:35 PM
Default Re: how much boost should i consider running? (brryder)
ttt..thanks
Old Mar 23, 2003 | 05:27 PM
ttt
Old Mar 23, 2003 | 06:17 PM
BoostedSi's Avatar
you could even run 20+psi tuned with race gas.
Old Mar 24, 2003 | 05:16 PM
Default Re: how much boost should i consider running? (BoostedSi)
ttt
Old Mar 25, 2003 | 03:22 PM
any more info guys?
Old Mar 25, 2003 | 03:52 PM
Mase's Avatar
im gonna say no more than 15 psi
Old Mar 25, 2003 | 04:22 PM
333's Avatar
333
19 PSI with Hondata. 20-23 PSI with a big turbo and 720cc injectors. I run 19 psi on a 18 g turbo, crower rods, srp pistons, 9.2:1 compression and hondata. Would run more but injectors are at 90% and the turbo is to small. Only got 333 horsepower to the wheels.
Old Mar 25, 2003 | 04:23 PM
333's Avatar
333
Default Re: how much boost should i consider running? (333)
I have 550 cc injectors. forgot.
HondaTom
Oct 10, 2005 04:33 PM
the DA in HONDA
Sep 1, 2004 08:55 PM
BOOSTED-EG
Jun 17, 2004 05:33 PM
12 oz.
Feb 28, 2002 07:51 PM
Markaccord95
Jan 11, 2002 11:34 AM
