BTM boost timing master help again!! HELP!
Old Mar 23, 2003 | 09:54 AM
avividmemory's Avatar
Default BTM boost timing master help again!! HELP!
Ok, well we got it all back in last week, motor etc...blah blah...and my friend hooked up the BTM but ever since then the car had been having trouble starting...so today i undid what he wired and the car starts right up! so, apparently we wired it incorrectly and that was causing all my problems...
So, now lets focus on the current problem...I need the BTM to be working so I can boost!! everything else is working like a charm the AFC V2 is doing great now and everything...
so please help me and tell me exactly where I need to hook the wires on a stock ignition teg...
someone before posted directions, but those directions were for a 6A ignition and not the BTM like i needed...so anybody that can help it would be greatly appreciated
TIA
Kevin
Old Mar 23, 2003 | 10:33 AM
IMALLSLO's Avatar
Default Re: BTM boost timing master help again!! HELP! (SpoolinLS)
Hook up the btm the same way as a 6 or 6a. The two extra wires are for the **** that goes in the car.
Old Mar 23, 2003 | 12:19 PM
Default Re: BTM boost timing master help again!! HELP! (proclassracer)
ok, maybe i should clarify...
there are 3 sets of wires...
set 1 goes to the distributor, its 4 wires; ground-black, dist ground-orange, dist power-red, signal-white
set 2 goes into the car to the ***, its 2 wires...
set 3 is also two wires purple and green, i dont know where they go or if i even need them...
that is what i have, its not the same as the 6a in terms of wires...i dont know where to connect the signal wire or if i have the others connected correctly to the ICM and what not...
Kevin
Old Mar 23, 2003 | 12:40 PM
UberTeg's Avatar
Just convert to obd1 and sell off the BTM and all that other gay crap, I told you i'd hook you up with a free chip
Old Mar 23, 2003 | 01:31 PM
AbaZ's Avatar
You dont use the purple and green wires... Its a pretty straight forward install, I suppose you already have the directions right? try looking over them again and just double checking your work, I have installed a few of these for people without problems.
http://www.jacksonracing.com/media/m...df/989-035.pdf
Jeff
00hondasi
Jun 7, 2009 07:45 PM
sPaRk'iT
Apr 26, 2004 05:46 PM
FastNFurious
Jun 19, 2003 05:30 PM
wutangben
Jun 9, 2002 08:35 PM
