Problem with SMC install!
Old Mar 19, 2003 | 06:52 PM
TurboDC4's Avatar
Default Problem with SMC install!
I hooked up my SMC 500 and now I throw a code 13 which is a barrometric pressure code. I try to reset it by either pulling the ground or pulling the ecu fuse, but it doesnt go away? Any idea what the cause is? My car runs ok but idles weird, im guessing because its in limp mode from the code? Any help would be appreciated!
Old Mar 19, 2003 | 07:00 PM
UberTeg's Avatar
Default Re: Problem with SMC install! (TurboDC4)
is the SMC500 out already? damn... Sorry I cant help yah w ith your problem
Old Mar 19, 2003 | 07:46 PM
zip's Avatar
zip
Richen the idle fuel mixture. The SMC500 and all other SMCs have adjustablility settings to adapt to various setups.
Old Mar 19, 2003 | 07:53 PM
UberTeg's Avatar
Default Re: Problem with SMC install! (zip)
muhahahahaha, you're late late, I already converted hm to the UberChip
Old Mar 19, 2003 | 07:59 PM
TurboDC4's Avatar
Default Re: Problem with SMC install! (UberTeg)
When idling the car surges a little. What would be a good starting point to put the fuel to?
Old Mar 19, 2003 | 08:03 PM
zip's Avatar
zip
Richen the Idle to 1.5K region at decreasing increments until it suits your setup. For example, from -35% richen the mixture to -33%, determine it's effect, then richen a bit more to -31% until idle is stable. Conversely, you can lean out the mixture by increasing the correction from -35% to -37% and so on.
Old Mar 19, 2003 | 08:05 PM
TurboDC4's Avatar
If im throwing the code 13, will this affect the fuel tables with the smc?
Old Mar 19, 2003 | 08:07 PM
zip's Avatar
zip
Have you already performed the ECU reset procedure I sent you via email and have calibrated the SMC settings to suit your setup?
Old Mar 19, 2003 | 08:09 PM
FAUCON's Avatar
The SMC 500 is out? Any info on your web site soon zip?
Old Mar 19, 2003 | 08:10 PM
TurboDC4's Avatar
Default Re: Problem with SMC install! (FAUCON)
No im about to go and do that.
Old Mar 19, 2003 | 08:28 PM
Evil EG's Avatar
also make sure you wires have a good connection on them! Make sure they are not loose! Also zip will you be putting vtec controll in any of these smc's?
Old Mar 19, 2003 | 08:29 PM
TurboDC4's Avatar
Default Re: Problem with SMC install! (BVM)
All the connections have been soldered and heat wraped
Old Mar 19, 2003 | 08:30 PM
TurboDC4's Avatar
Im sure vtec would not be a problem to incorporate into it. Am I right ZIP?
Old Mar 20, 2003 | 06:53 AM
TurboDC4's Avatar
Well, I got rid of the code. I have got the whole rpm set fine except for the 0-1000 rpm range.
1-2 =37
2-3=35
3-4=35
4-5=35
and so on..... My idle however is at 30 and it surges a little, if i move either way 3% it does the same thing, but if I go any further the car dies? Is that the best idle im gonna get??
dracocrx
Apr 10, 2009 05:47 AM
digital sol
May 19, 2006 07:50 AM
90civichb
Aug 12, 2005 01:14 AM
Turbohatch
Sep 10, 2001 08:38 AM
