Rev hard kit
Old Mar 21, 2003 | 10:32 PM
turbospool's Avatar
Default Rev hard kit
i finally got my rev hard 2c kit after so many weeks of waiting. First thing is the turbo is a turbonetics, is this normal? Its polished compressor housing. How can i tell if its a t3/t04e and not a t3/t04b? On the turbine it says, .63 a/r and stg 3. i thought 2c comes with a nutec or precision turbo... anyways. the piping from the turbo to the intercooler is only 2 inches in diameter. Is this normal? Then the piping from the intercooler to charge pipe is 2.25 and the charge pipe is 2.5. Help me, thanks.
Old Mar 22, 2003 | 02:26 AM
turbospool's Avatar
Default Re: Rev hard kit (turbospool)
bump
Old Mar 22, 2003 | 06:02 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
You will be fine with that pipng. You don't need bigger unless your running tons of boost. With bigger piping and not enough boost you may lose a little. SOunds normal to me.
Old Mar 22, 2003 | 08:19 AM
vtec.dc2's Avatar
http://www.turboneticsinc.com/catalog/comp_wheels.html - you can measure to tell if the size of compressor
http://www.turboneticsinc.com/catalog/twheel.html - if it already states .63 a/r then it most likely is.
Old Mar 22, 2003 | 08:35 AM
wickedxboi's Avatar
Default Re: Rev hard kit (vtec.dc2)
the e compressor housing should be alot bigger then the b housing.
Old Mar 22, 2003 | 10:20 AM
shadowdawn's Avatar
Default Re: Rev hard kit (wickedxboi)
With my rev hard kit I got a .63 a/r stage 3 wheel turbine, and the t04e compressor, which is amazingly stamped with only 50 .AR It's still huge tho.
Old Mar 22, 2003 | 11:16 AM
turbospool's Avatar
Default Re: Rev hard kit (shadowdawn)
The turbine says .63 a/r and stage III. The compressor side says nothing but Turbonetics and the backing plate is this annodized blue. The inlet is only 2.5.
Old Mar 22, 2003 | 11:27 AM
shadowdawn's Avatar
My guess is you have the t3/t4b turbo because 2 friends have it, its a bit smaller then mine and the compressor is polished, whereas all the t3/t4e's I saw were considerably bigger on the compressor side and did NOT come polished.
Oh and my compressor inlet is 3"
[Modified by shadowdawn, 3:27 PM 3/22/2003]
Old Mar 22, 2003 | 11:40 AM
turbospool's Avatar
mr.cheap turbo said the t04e has a six blade wheel on the compressor side and seven blade for the t04b. I have the six blade and he said the inlet was 2.5 becuase it was .50 on the compressor side. what u guys think?
Old Mar 22, 2003 | 12:04 PM
turbospool's Avatar
john from afterhourz also said 2 inch from turbo to intercooler is to prevent pressure drop. then out the intercooler its 2.25 and then 2.5 to tb. what u guys think bout this too?
imationdawg
Jul 12, 2009 10:06 PM
not2slo128
Aug 29, 2006 08:22 AM
jdm-ray
Sep 8, 2005 09:45 AM
the.hamburglar
Jun 13, 2005 10:04 PM
