2.5 or 2.25 outlets on a starion IC?
Old Mar 23, 2003 | 10:41 AM
-Racer X-
Guest
Posts: n/a
Default 2.5 or 2.25 outlets on a starion IC?
buying a starion IC, gettin the outlets on the entanks welded, what size should i go with? 2.5" or 2.25"? ill be runnin 7psi on the street, no more than 11 at the track, and im not certain if i will build my bottom end for more boost, so what would you guys suggest?
thanks
Old Mar 23, 2003 | 11:08 AM
-Racer X-
Guest
Posts: n/a
Default Re: 2.5 or 2.25 outlets on a starion IC? (-Racer X-)
up
Old Mar 23, 2003 | 11:55 AM
93LSivic's Avatar
I used to have a starion. You cant go bigger then 2.25 on the tanks, its only that wide to begin with.
Mine was good enough to run 12's on 11 psi boost. JB welded too!
eightvalver
Apr 16, 2006 11:50 AM
1SlowSi
Nov 9, 2004 05:32 AM
DCFIVER
Oct 1, 2004 08:22 AM
-Racer X-
Mar 23, 2003 10:40 AM
SOHC_MShue
Mar 13, 2003 03:41 PM
