LS pistons in GSR block
Old Mar 23, 2003 | 01:04 PM
RAWB's Avatar
Default LS pistons in GSR block
Has anyone run this setup? Right now I have a gsr block/crank that is going to be mated on a B16 head. Instead of using the gsr pistons/rods, can I use LS pistons on the GSR rods to get an even lower compression to boost with(aprrox 9:4:1 vice the 9:8:1 with the GSR's)
Old Mar 23, 2003 | 01:06 PM
Kwuaymaikrup's Avatar
Default Re: LS pistons in GSR block (RAWB)
I am not certain but I believe the problem with that lies with the valve reliefs on the LS pistons. I don't think they are sufficient enough to clear the valves on a vtec head.
-Ryan
Old Mar 23, 2003 | 01:43 PM
hybrid901's Avatar
Default Re: LS pistons in GSR block (Kwuaymaikrup)
They arn't
Old Mar 23, 2003 | 02:52 PM
rioninja's Avatar
I have LS pistons in my 2nd gen B16a. And these guys are right, i had to enlarge the valve releifs. It should net slightly below 9:1 compression.
Old Mar 23, 2003 | 03:41 PM
Boostfed's Avatar
New User
9.75:1 CR accoridng to the c-speedracing site, I also believe that the LS pistons may not have enough valve relief you would have to clay the motor.
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old Mar 23, 2003 | 03:51 PM
RAWB's Avatar
Default Re: LS pistons in GSR block (Boostfed)
Right on, fellas. Just thought it might be worth a try
9:8 with the GSR's should be alright for now. Thanks.
sleepencivic
Oct 21, 2010 08:57 AM
almostjdmeg
Oct 8, 2008 08:33 AM
KRWTEK1
Sep 3, 2006 08:49 PM
92eg6lsvtec
Jul 22, 2005 12:11 PM
sadcivic
Sep 25, 2003 08:00 AM
