detonation??
Old Mar 20, 2003 | 04:32 PM
DuMpTuBe's Avatar
Default detonation??
Here's the scoop. 2000 Honda Prelude w/aftermarket turbo kit installed awhile back. Stock internals, 5-6psi boost. Deltagate, V-AFC, AVC-R, basic set-up. Running a step colder NGK plugs, and MSD 6BTM timing control. Still seeming like getting detonation and EGT temps are creeping past 1400 F. Does not boost well at all. Tried different fuel correction settings (as high as 35%) on V-AFC to try to cool it down, but still doesn't seem right. Anyone run into this before or have any suggestions?
Old Mar 20, 2003 | 05:03 PM
sharkcohen's Avatar
Default Re: detonation?? (DuMpTuBe)
Are you running an FMU or larger injectors? What is your MSD BTM set at? Have you bothered getting your setup tuned with a wideband? Stop boosting until you fix this problem or you are going to toast those pistons.
[Modified by sharkcohen, 2:04 AM 3/21/2003]
Old Mar 20, 2003 | 05:06 PM
civictypenos's Avatar
Default Re: detonation?? (sharkcohen)
what he said!!
Old Mar 20, 2003 | 05:08 PM
sharkcohen's Avatar
H22A4 + detonation = boom
Old Mar 20, 2003 | 07:56 PM
DuMpTuBe's Avatar
Its the full drag 2 kit. So yes there is the FMU. Stock injectors. I have messed with the BTM in many different settings and it doesnt seem to help. The egt runs high, and the Apexi afr flucuates between 12 and 18. I do have the V-AFC turned up to 35% in Hvt. ANy sugestions
Old Mar 20, 2003 | 09:54 PM
MikeMAN's Avatar
most honda engines + detonation = boom (all it takes is 1 time..and the most dangerous detonation is the type u can't hear)
don't ask me how I know this and don't ask me if I am getting new SRP 9.5:1's installed right NOW
mike
Old Mar 20, 2003 | 09:56 PM
sharkcohen's Avatar
You cannot just mess with your settings and hope for the best. You cannot rely on the Apexi a/f display, as it is still running off of your unreliable, stock, narrowband 4 wire O2 sensor system. You must get a fuel pressure gauge and have your setup tuned by a professional on a dyno with a wideband. There is no way around this. Keep going down the road you are, and you will be looking at a full engine rebuild. What you should do is dump the FMU, get appropriately sized injectors, get electronic engine management, and then get your setup tuned. And if you think you can't do any of this because it is too expensive, then you got yourself into the wrong hobby, and an engine rebuild is going to cost you $3k-$5k anyway, so you might as well do things right now or sell everything now and return your car to stock.
But whatever you do, STOP BOOSTING ON YOUR SETUP BEFORE YOU BLOW YOUR H22A4 MOTOR.
[Modified by sharkcohen, 6:57 AM 3/21/2003]
Old Mar 20, 2003 | 10:03 PM
sharkcohen's Avatar
Your stock injectors are already working at over 80% duty cycle, there is no room for the VAFC to richen the mixture. On your setup, the only thing a vafc is good for is leaning out areas of the rpm band. You are supposed to be relying on your FMU to supply the fuel you need, and using the VAFC to lean areas out that need it. All of this requires a fuel pressure gauge, a dyno, a wideband, and someone who knows what they are doing.
Old Mar 21, 2003 | 12:15 AM
93H22ACX's Avatar
i had the same problem....stock injectors, with inline and fmu....it didnt run well at all so i bought the V-AFC.....i only leaned it out -12% from 3000rpm - 8000rpm and VTEC contin at 4800 or 4900rpm (can't remember) and set the BTM at .65 or so and it runs pretty good. i will not do anymore until i get it on a dyno though.....and its pushing 6-7psi now.....
before that it did not run good at all.....after that setting i took it out to the tracks and ran a 14.33@102mph @5.5psi....only one run though...no helmet.....plugs looked good....greyish in color
[Modified by 95PRELUDEVTEC206, 9:16 AM 3/21/2003]
[Modified by 95PRELUDEVTEC206, 9:17 AM 3/21/2003]
rlwturbosi
Oct 11, 2005 05:58 AM
quik sol
Aug 24, 2004 05:22 PM
Cee_mon
Jul 22, 2003 07:28 PM
turboedef9
Apr 29, 2002 09:27 PM
greyzone
Dec 14, 2001 09:54 PM
