fjo wideband +aem HELP!
Old Mar 22, 2003 | 11:43 PM
BoostedSi's Avatar
Default fjo wideband +aem HELP!
Ok, i just installed the fjo. What do i do with the stock o2 sensor??unplug it??? Its still plugged in and i 'm running both sensors.
btw, i teed the fjo signal wire to the primary o2, lambda wire.
Also, how do i check the a/f on the aem? Man i'm totally lost.
Old Mar 23, 2003 | 05:54 AM
niedejb's Avatar
Default Re: fjo wideband +aem HELP! (BoostedSi)
I'd like to know as well. The AEM board isnt very clear on wiring of the FJO.
Old Mar 23, 2003 | 07:54 AM
98Psi ITR's Avatar
Default Re: fjo wideband +aem HELP! (niedejb)
http://www.fjoinc.com/automotive/dow...%20Manual).pdf
have you read this yet?
Old Mar 23, 2003 | 07:57 AM
93LSivic's Avatar
You need to plug in the FJO AFR numbers into the Oxygen #1 raw volts table. Then you will want to compare afr reading between the ems and fjo display (you have the display right?). This can be found by going to Setup--Sensor setup-- O2 sensor. To align them you will need to goto O2 #1 options gain---should be something like .95 - .97. You want the two displays to read the same afr.
Old Mar 23, 2003 | 08:13 AM
BoostedSi's Avatar
Default Re: fjo wideband +aem HELP! (93LSivic)
i thought i didnt need the display since i had the aem???
Old Mar 23, 2003 | 08:22 AM
BoostedSi's Avatar
What do i do with the stock o2 sensor????just leave it in the exhaust and unplug it???
Old Mar 23, 2003 | 08:46 AM
93LSivic's Avatar
Well, you really dont need the display...but I would want it--are you really gonna drive around all the time with the laptop on the seat so you can look at your afr?
Anyways, yeah just plug up the stock sensor hole.
Here is that cal spec for loading the ems
Old Mar 23, 2003 | 08:52 AM
DeepSi's Avatar
you dont need the display if you have the fjo hooked up to the EMS. you can leave the o2 sensor plugged in and still use the fjo
Old Mar 23, 2003 | 09:00 AM
niedejb's Avatar
Default Re: fjo wideband +aem HELP! (DeepSi)
Soooo.
Does the AEM use two different pins than the stock sensor? Or do you use the stock sensor wiring for the FJO connection?
Old Mar 23, 2003 | 09:08 AM
BoostedSi's Avatar
Soooo.
I used the fjo connection. Left the stock sensor still plugged up. My only problem is my readings look all messed up. Something doesnt seem right. And the only place i know how to check the a/f is in the o2feedback, parameters. Man i'm totally lost
Old Mar 23, 2003 | 09:11 AM
niedejb's Avatar
OK.
How does it connect to the EMS unit? Through seperate pins or the original O2 sensor pin locations?
Old Mar 23, 2003 | 09:13 AM
BoostedSi's Avatar
OK.
With the black 4-pin square connector i did these to the wires:
white wire: 12v power source
Black: grounded it
red: teed it into the wire that goes into the ems(o2 primary, lambda)
green: teed it into the wire that goes into the ems(sensor ground)
hatche1
May 4, 2011 06:19 PM
h22_crx
Nov 14, 2006 08:07 AM
SpeedMonkeyRacing
May 12, 2003 12:41 PM
underpressure02
Mar 6, 2003 08:32 AM
