Went to the track with the Auto again!!
Old Mar 19, 2003 | 10:21 PM
shadowdawn's Avatar
Default Went to the track with the Auto again!!
I went to englishtown today and actually got 4 runs in on a wednsday!! Thats amazing in itself. However I beat my previous best of 14.4 at 98.9 to hit my highest goal (with the auto) of LOW 14's and I am now a member of the 100mph club!!!!!!!!!!!!!!!!!
R/T: .772
60': 2.413
330: 6.298
1/8: 9.409
MPH: 78.29
1000: 12.093
1/4: 14.338
MPH: 101.29
I'm SOOO STOKED!!!!!!! for me, and for my baby!!!
Old Mar 19, 2003 | 10:46 PM
XDEep's Avatar
Default Re: Went to the track with the Auto again!! (shadowdawn)
good job! i cant believe youre running stock internals on the slushbox at 8psi and its been holding up well? havent thought about a tranny oil cooler? i thought those would be a must.. well my setup isnt gonna be as nice as yours but still inspired from it
Old Mar 19, 2003 | 11:08 PM
sharkcohen's Avatar
Very nice time for an auto
Old Mar 20, 2003 | 12:23 AM
incogNitto's Avatar
full interior?
had your system in?
for you and for auto power
edit: launch technique?
[Modified by incogNitto, 4:24 AM 3/20/2003]
Old Mar 20, 2003 | 09:49 AM
shadowdawn's Avatar
Default Re: Went to the track with the Auto again!! (incogNitto)
Yes basically full interior, only things removed were spair, jack, the boob box and school books.
Old Mar 20, 2003 | 09:55 AM
@irborne's Avatar
14.3, eh! now a high 13sec would be a good goal
Drew Peacock's Avatar
Nice times thats a fast auto there! Wonder if you can get your 60ft times any better, are you spinning much off the line? What rims and tire you using on the front?
Old Mar 20, 2003 | 10:03 AM
shadowdawn's Avatar
Default Re: Went to the track with the Auto again!! (turbozxi)
Ran with stock 15"s and I doubt I can get much better, I'm thinking optimally a 2.39 would be like the best I could pull. I occasionally chirp, but never blatant spinning off the line. If you ask me thats better, traction is awesome especially since first gear boost in an auto is something everyone who's never been in one should experience. Its fuckign scary man
Old Mar 20, 2003 | 10:06 AM
93LSivic's Avatar
Are you able to brake boost at all with the auto? Ive been trying it on my car, but its pretty hard to control the clutch, brake, and gas at the same time.
Old Mar 20, 2003 | 10:12 AM
shadowdawn's Avatar
Default Re: Went to the track with the Auto again!! (93LSivic)
Honestly I'm not sure if I'm building boost at the line, I am torque breaking up to 3000rpm ish area, but theres not like enough time for me to watch revs, and the lgihts at the same time. Ran a few reds last night trying. It's a feeling thing, I can tell right after a launch if I did it right.
Old Mar 20, 2003 | 11:05 AM
accordexchange's Avatar
i have a boosted auto too... good job..! automagic..!
Old Mar 20, 2003 | 11:33 AM
ill_take_one's Avatar
Default Re: Went to the track with the Auto again!! (accordexchange)
nice times man!
Keep up the good work!
Old Mar 20, 2003 | 11:44 AM
gritsak's Avatar
you need a 2step
Old Mar 20, 2003 | 12:01 PM
93LSivic's Avatar
Default Re: Went to the track with the Auto again!! (gritsak)
2step in my hondata didnt allow boost. You really need to put a load on the motor to build any kinda boost.
Old Mar 20, 2003 | 12:25 PM
Scott - 93HB Si's Avatar
Crap, I thought it would work.....Talon guys are building boost off the line with a stutter box.....why doesn't it work with a hondata? Is your turbo just too massive?
Old Mar 20, 2003 | 01:45 PM
XDEep's Avatar
Default Re: Went to the track with the Auto again!! (Scott - 93HB Si)
on your site you say that you never chirped before.. how can you not peel out/chirp? you can do that with a stock auto even.. what kind of tires?
Old Mar 20, 2003 | 04:30 PM
shadowdawn's Avatar
Default Re: Went to the track with the Auto again!! (XDEep)
Stock michellins, I've never chirped from a complete stop, or shifting, and don't see how thats possible unless the ground is slick, sandy or something.
Get in a stock auto teg and floor it or lightly power brake it, I HIGHLY doubt you will get any kind of chrip from the tires. I mean I'm turbo and I can barely chirp them. I'm not really complaining tho, 2.41 60's is better then most peoples hondas that are stick that goto e-town when I'm there. I see lots of 2.5's and 2.4's
Yes I know a GOOD driver can get down to 2.1 and 2.2's on street tires, but obviously it takes a really good driver.
Old Mar 20, 2003 | 05:47 PM
XDEep's Avatar
thats odd. i'd think with stock michelins you can make them squeal like a schoolgirl. whats your camber at? MANY people can chirp tires off the line, sometimes in 2nd, SOME even in 3rd (probably with horrible alignment). i did it with stock tires, chirped 2nd. then i got a camber kit and of course could do it easier, could do it with falken ziex.. however i cant seem to get any noise out of my dunlops with 200treadwear.. only on corners.
Old Mar 20, 2003 | 06:02 PM
shadowdawn's Avatar
Your forgetting how much different worlds stick to auto is, auto has no ability of launching at any rpm unless you nuetral drop it... and if you nuetral drop it you really want to blow up your tranny quickly.
Old Mar 20, 2003 | 06:19 PM
MyWhiteCivic's Avatar
shadowdawn, nice times.
accordexchange, hows that junker running? j/k How have you been?
Old Mar 20, 2003 | 07:04 PM
XDEep's Avatar
Default Re: Went to the track with the Auto again!! (MyWhiteCivic)
brake torque
Old Mar 20, 2003 | 08:15 PM
BoostedSi's Avatar
if you talking about chirping tires..thats just depends on the clutch you have. I used to be able to chirp 4th easily and sometimes 5th if'm i'm lucky with my CM stage 4 clutch.
Now that its getting older...i'm lucky to hit 3rd
btw, nice times...those 60's are pretty nice. Last time i went to the track i had 2.5 60's..hehe
Old Mar 20, 2003 | 10:00 PM
Finest's Avatar
Default Re: Went to the track with the Auto again!! (BoostedSi)
DID YOU NOT READ THE TITLE OF THE POST? OR EVEN READ SOME OF THE POSTS CONTAINED HERE WITHIN?!!!
Old Mar 20, 2003 | 11:56 PM
96IntegraRS's Avatar
Default Re: Went to the track with the Auto again!! (98CTRCoupe)
Hehehehe.... Yep, with that torque converter model "clutch" I bet you can rip 3rd.
Anyway, nice times! You seem to be getting faster and faster, what is new/different besides the cold (you're in NJ right?)
Old Mar 20, 2003 | 11:57 PM
Again, as you have discussed, you must be making 225 WHP or so to fight the drivetrain loss - nice work.
