Garret t3t4
Old Mar 22, 2003 | 11:15 AM
BoostedsiR's Avatar
Default Garret t3t4
garret t3t4 on a b16 with cam gears hondata w/boost rc 440 Ive been hearing good and bad things about how the turbo spools someone told me 5000 to 5500 that is high as **** and I heard it is between 3500 and 4500 can someone give some good input
Old Mar 22, 2003 | 11:20 AM
Smashback's Avatar
Default Re: Garret t3t4 (BoostedsiR)
well, your first problem is the misconception that every t3/t4 is the same. there are what....a zillion different trims out there. You need to figure out what compressor/turbine combo is the best for your engine and at the same time you can determine approx spool up time.
I will tell you that I've never heard of it taking until 5000 RPMS to spool any t3/4 on a B16. It only took until approx 4000 RPMs on my SOHC with a t3/t04b
littletriad
Aug 10, 2006 02:41 PM
rudebwoy
Dec 12, 2005 12:39 PM
model x
Jun 4, 2004 02:32 PM
jdmcivicek
Jul 2, 2003 08:30 PM
BlueSi2k
Apr 15, 2002 07:05 PM
