y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak????
just started her up for the first time and pulled the plugs they were filled with oil and antifreeze.... do i need a special headgasket for this setup or was the headgasket not sealed right???
Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (aemcivic_02917)
did u put on the gasket the right way??? did u also trouqe the head bolts?
[Modified by SPOON_BeIgHtEeNsEe, 7:14 PM 3/20/2003]
sounds like you forgot to put the gasket in all together...or maybe you left a wrench on top of the block when you isntalled the head
J/K that's not normal, obviously. I never had any problems with mine. Did you use a NEW gasket?
Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (SPOON_BeIgHtEeNsEe)
yes im 99% i put the headgasket on correctly, and i torque the head twice in the right seq. order. im guessing i need a headgasket made or was this a result of poor install?
brand new y8 headgasket from honda i re used the head bolts too b/c the arp bolts didnt fit
Just replace it again, something went wrong unless there is something wrong with the head or block.
Everybody whines about not re-using head bolts but there's no problem doing so. 90% of engine builders don't replace head bolts just for the heck of it.
Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (Hatchblack)
so u guys with y7 bottom ends and y8 heads do you use a Y7 or Y8 headgasket .. let me know peeps i need to know asap.....
btw i had the head resurfaced would that raise the compression? also it didnt leak around the outside of the block so is there anyway when i take the head off would i be able to tell where it was leaking from?
[Modified by aemcivic_02917, 11:40 AM 3/20/2003]
If your deck/sleeves are out of what this could happen but I doubt that's it. If I remember right, the Y7 and Y8 gaskets are the same. I think I used a Y8, but I do think they are the same. Look up the part numbers at autozone and check them.
i think yoru supposed to take out one of the oil restrictors on the block
would resurfacing my head raise the compression?
Hope this helps.
BTW, I've seen this before when resurfacing was done crappy.
Actaully, if you just resurfaced and didn't take out any serious amount of metal in the process, then it wouldn't raise the comp. Just wanted to put that in for those falmers out there...
[Modified by JRSCCivic98, 1:49 PM 3/21/2003]
Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (JRSCCivic98)
the head was resurfaced by a machine shop. i hope i can find out what caused it when i take the head off or where it was leaking from i doubt it was from the head being resurfaced, i just wanna know what caused it to leak inside of the head and not around the outside of the block
If you re-install another headgasket, why don't you try some copper spray on the new gasket.
Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (SDT Project EF)
Nope, you've been reading too much about the older SOHC motors. D16Y8 head bolts straight onto a D16Y7 block with no modifications other than wiring.
justinCO
06-10-2008 09:16 AM
