who's making close to 350whp and what setup?
hey sup folks, need some of every ones expertise. my goal is to make nearly around 330-350whp. who on here makes that much and willing to share your setups. this is on a 98 integ gsr my mods are as listed below.
apexi s-afc, msd 6btm w/blaster 2 coil
eclipse fuel pump
b&m fr
rc 440cc
crower rods, valves,dual springs,titanium retainers
je 9:1
any thing i'm missing?
what turbo setup would produce that much whp with what i have? trim,a/r?
not that much lag? please help..thanx
[Modified by luckypon7, 2:42 PM 3/21/2003]
eclipse fuel pump
b&m fr
rc 440cc
je 9:1
Re: who's making close to 350whp and what setup? (luckypon7)
Good luck trying to do that with 440's and a damn SAFC,,
you need bigger injectors, and a standalone!!!!]
Then tune,tune,tune tune!!!!
Brian
Brian
Re: who's making close to 350whp and what setup? (TurbodCX)
wow! 400whp on sohc very impressive. i know i need to get standalone sometime, what system are you running? what would 440cc be able to support 300 at least?
1 Post
Re: who's making close to 350whp and what setup? (Tinker219)
someone maxed out 450s at 287 on here...I think they mightve even been a little bigger...
I am running a Hondata 4B with Nippondenso 550cc injectors, which i know are NOT going to be big enough fr me, i am buying a set of 720 as we speak.
That is why i am saying the 440's wont be big enough, i looked in my logger and at about 15-20psi i will be at a 100% duty cycle..
Brian
Brian
Re: who's making close to 350whp and what setup? (LSDelSol)
361 hsp to the wheels:
stock b18c1
inlinepro 3mm headgasket
afc
stock ecu
fmu (12:1)
440's
just about any trim t3/4
race gas
[Modified by jinxproof99, 11:03 AM 3/21/2003]
stock b18c1
afc
stock ecu
fmu (12:1)
440's
race gas
Re: who's making close to 350whp and what setup? (jinxproof99)
Inline does that alot with there cars, because of the race gas, and the high timing in the stock computer, which they take care of with race gas.
They do get good #'s out of this setup, but only on Gas..
Brian
... i am hoping for around 325 whp also... here's what i have:
- T3/60-1 .63 a/r
- 9.8:1 JE pistons
- Eagle rods
- ARP headstuds
- ACL bearings
- 550cc injectors
... (what i still need to get)
- Hondata
- STR blockguard
... so what does everyone think?... will i hit 325+ whp?... how much boost will i have to run to get there?... lemme know... thanks...
- T3/60-1 .63 a/r
- 9.8:1 JE pistons
- Eagle rods
- ARP headstuds
- ACL bearings
- 550cc injectors
- Hondata
- STR blockguard
Re: who's making close to 350whp and what setup? (1.8T_EG)
some of you guys are running some good numbers, would like to be one of you guys. i read most people pick resleeving there block over blockguard due to BG calapse the top of the cylinder..is that correct? thanx you guys for the inputs and opinions keep them coming.
[Modified by luckypon7, 4:35 PM 3/21/2003]
Brian
Brian
Brian
This is on 10psi, full 2.5 exhaust and pump gas.
EDIT: dyno sheet
[Modified by autoEXturbo, 12:51 PM 3/21/2003]
Re: who's making close to 350whp and what setup? (autoEXturbo)
sorry but i think he was talking about my 440cc injectors making 300 above not making 440whp w/ s-afc....
autoEXturbo sorry my bad, i went back and read it your right.. i wasn't under stand it..thanx for your opinion you posted.
no problem man, i wasn't trying to get an attitude, i kinda re-read it and it sounded that way. It's very possible with the right tunning to run 350 with an afc and 440's.
Re: who's making close to 350whp and what setup? (QCKGSR)
the man who made 320 is running lean with that 13.0 a/f
EDIT: and get it right, it was 326 damn it
[Modified by autoEXturbo, 9:03 PM 3/21/2003]
u guys think its possible to make about 300 whp with a
b16a(stock)
t3/60-1
450's
v-afc
pumpgas
and the usual bolt ons, camgears,ITR mani+TB,etc,.
what do think....?
b16a(stock)
t3/60-1
450's
v-afc
pumpgas
what do think....?
