Adapter help
Old Mar 21, 2003 | 07:39 PM
B18Flip's Avatar
Default Adapter help
What kind of adapter do i need to hook up my ac autotechnic oil filter block to my oil feed? I'm not really sure what size the line is, but it came with the drag oil kit (-3 or -4?).
I looked through homedepot and couldn't find one that would fit . Here's some pics, I guess its what ever size the size the tapered end is because it fits botht he line and the block.
Fitting on the line
Fitting on the block
Old Mar 21, 2003 | 07:43 PM
integra-modder's Avatar
Default Re: Adapter help (B18Flip)
Originally posted by 93LSivic
Ok, another member just PM'd me and asked the famous question about the feed and return lines. This is what I wrote back to him. THIS IS HOW I DID MY SETUP! SOme of you may choose to have the "T" mounted on the firewall, if you do this, then you WILL NEED 2 more 981604 and 2 more 300104 and you wont need 991101.
Be sure to save this post, cause we all know that this question pops up 3 times every week and not too many people put together an organized shopping list.
This is what I wrote:
OK, I just spent a half hour putting together a shopping list for you. Keep in mind this is exactly how I did my feed/return system. I decided not to use the factory oil sensor because i went with a mechanical oil pressure gauge that runs off the feed "T" coming off the block. Also I used a union in the pan---drilled bigass hole and sealed with silicon, in this case Im giving you stratoseal p/n so you can do it right (which I didnt do--in light of getting turbo install done)
All part numbers are from amstreetrod.com ---best prices and parts are always in stock.
Feed:
1/8 nipple for block -- 991101
1/8 "T" -- 991701
1/8 to -4AN -- 981604
(2 needed) -4AN straight swivelseal hose ends -- 300104
(4 ft needed) -4AN ss hose -- 400040
For adapter to turbo you will need one of these depending on the size of the hole on the turbo itself.....
1/8 npt hole 982204 (Smaller T3's use this one I believe)
1/4 npt hole 982244 (This was the one I used for my t3t4)
Return:
Aluminum return flange found at turbocharged.com p/n is 20259.
-10AN flange side male to hose -- 824510
(2 ft needed) -10AN hose -- 400100
-10AN 45 to pan fitting -- 804610
-10AN union for tapping pan -- 981510
-10AN bluhead nut for union in pan -- 992410
Stratoseal for union (package includes 2) -- 178014
This should be all. Probably a little on the pricey side, but no one ever said going turbo is cheap!!
Happy Boosting!
Maybe this will be of some use...
Old Mar 21, 2003 | 07:49 PM
B18Flip's Avatar
Default Re: Adapter help (integra-modder)
yup everything is covered...the only thing is that i bought the drag oil kit , and i dont know what size the oil feed fittings and line is.
Old Mar 22, 2003 | 05:00 AM
B18Flip's Avatar
is anyone else running the ac auto. oil dist. block?
Old Mar 22, 2003 | 05:15 AM
bruthaboost's Avatar
I'm using the same oil dist block. I don't have the Drag oil supply line, but it looks like a size 3 an. The dist block has 1/8" npt.
HTH
Old Mar 22, 2003 | 03:00 PM
B18Flip's Avatar
Default Re: Adapter help (bruthaboost)
HTH
cool thanks! yeah i think it is 3an because the t-fitting has a number 3 on it
Old Mar 22, 2003 | 03:10 PM
krazy's Avatar
i bought the golden eagle one. it came with it. maybe PM golden eagle to see what size theeirs are.
krazy
Old Mar 22, 2003 | 05:48 PM
Flamenco-T's Avatar
Default Re: Adapter help (krazy)
you need a 1/8" to -3AN adapter fitting male to male
stan
Old Mar 22, 2003 | 10:01 PM
Default Re: Adapter help (Flamenco-T)
this place has the lowest prices on earls stuff
Old Mar 22, 2003 | 11:51 PM
B18Flip's Avatar
stan
Thanks stan
Old Mar 23, 2003 | 12:18 AM
LiLOtaku's Avatar
any of you guys know where I can get one of those ac autotechnic adapters for a decent price?
Old Mar 23, 2003 | 07:23 AM
B18Flip's Avatar
Default Re: Adapter help (LiLOtaku)
I got it from here http://216.82.69.117/search_results....hnic+oil+block , but i know afterhourzracing.com sells them too.
Old Mar 23, 2003 | 09:24 AM
LiLOtaku's Avatar
Thanks Flip,
you just saved me 30 bucks. I was gonna get it from afterhourz for 89 bucks, but autodynamics has it for 59 .
Old Mar 23, 2003 | 10:32 AM
Thanks Flip,
ask in best buys forum and then search around through google...
[Modified by integra-modder, 2:33 PM 3/23/2003]
mrx
Oct 30, 2005 09:08 AM
vtec.dc2
Apr 17, 2005 02:33 PM
FOrSfEd
Aug 13, 2004 12:03 PM
Tad
Mar 13, 2004 11:32 PM
reignofchaos
Aug 3, 2003 10:24 PM
