dsm 450cc injectors
Old Mar 22, 2003 | 03:01 AM
turb's Avatar
Default dsm 450cc injectors
how can you identify a dsm 450cc injector? aside from the blue color power connectors. any markings that i should look for?
i tried searching about this topic but i could find one.
thanks
Old Mar 22, 2003 | 05:37 AM
b18b98's Avatar
Default Re: dsm 450cc injectors (turb)
it should say 450 on the side
Old Mar 22, 2003 | 05:43 AM
JT's Avatar
JT
Blue top, black tip = 1G DSM 450cc
Black top, green tip = 2G DSM 450cc
The flow rate is stamped on the side.
Old Mar 22, 2003 | 05:55 AM
b16 matt's Avatar
Default Re: dsm 450cc injectors (JT)
I thought dsm's were 440's
Old Mar 22, 2003 | 06:03 AM
JT's Avatar
JT
Default Re: dsm 450cc injectors (b16matt)
The DSM turbo models are 450. RC uses 440.
Old Mar 23, 2003 | 11:46 PM
turb's Avatar
so the one in the picture is the 2G dsm injector right? when you say tip is it where the fuel squirts out or is it where it is connected to the fuel rail? sorry..i'm not too familiar with injectors. hehe
do you happen to have a picture of the whole injector?
thanks again
Old Mar 24, 2003 | 12:01 AM
Sh4rky's Avatar
Are there any 550cc DSM injectors? Also, what's the max HP you can get a b18c to with 450cc injectors, running AEM EMS?
Old Mar 24, 2003 | 12:03 AM
ion_four's Avatar
as b18b98 said..."it should say 450 on the side"
the "tip" is the end where the fuel comes out. If it says something"450" on it, you are fine. Or, you could get them cleaned and flowed/balanced to know for sure. I'm sure there are threads on where to get your injectors cleaned.
Old Mar 26, 2003 | 12:44 AM
turb's Avatar
is there any other mitsu engine other than a 4G63T where 450cc injectors are used? does the v6 galant engine use 450cc injectors? not quite sure of the engine code on the v6.
Old Apr 2, 2003 | 02:17 PM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
The vr6 galant and the mitsu lancer evo both have 510cc injectors but are far less common than the 450cc. You can boost 18psi (not highly recommended)on a B18 with a t3t4 with the proper fuel pressure which is said to be 40psi. I just made the 450cc dsm swap in my 94 integra gsr because i put a drag III kit on.
h23vtec_dc2
Mar 31, 2014 09:53 PM
TURBO DC2
May 6, 2005 06:36 AM
J2turbo21
Aug 16, 2003 05:43 PM
threatcon13
Jan 31, 2002 08:32 AM
