how does a boost controller work
Old Mar 21, 2003 | 03:44 PM
viprcr1's Avatar
Default how does a boost controller work
I wanted to know how a boost controller works. I thought that the wastegate regulates the boost by a spring that you have to replace on the inside so how does a boost controller do tha? I know this is a stupid question so just bare with me please.
Old Mar 21, 2003 | 06:20 PM
Foozball26's Avatar
Default Re: how does a boost controller work (viprcr1)
profec B sends pulses of air from that black box (motor) which regulates it.
It basically "forces" the spring not to contract thereby allowing more boost than the spring is rated for.
It works like a BOV, the air in the charge pipe is trying to puch the BOV open but the line you hook up to it keeps it closed.
Old Mar 21, 2003 | 07:17 PM
viprcr1's Avatar
Default Re: how does a boost controller work (foozball-26)
oh kool thx a lot.
I thought no one was gonna reply
Old Mar 21, 2003 | 10:13 PM
poid's Avatar
Basically the boost controller bleeds off some of the boost before it reaches the wastegate. So if you want to run 10psi, and you wastegate has a 7psi spring, the boost controller will bleed off boost so that at a full 10psi boost the wastegate will see 7psi and open.
nychonda
Jul 1, 2009 04:37 PM
c61lude
Jan 19, 2006 04:34 PM
GDM Z28
Nov 30, 2003 06:13 AM
1tyme
Nov 27, 2002 05:32 PM
accordfreak
Dec 25, 2001 12:20 AM
