turn up the boost....
Old Dec 29, 2003 | 04:07 PM
kcjohnnyboy's Avatar
Default turn up the boost....
i have a greddy turbo kit on my 99 integra gsr and was wondering how to turn up the boost...what do i need to do to go more than 8 psi... i have all the hardware that was included in the kit installed...can you guys help...since 8 psi isnt enough for me... ... is it something to do with the wastegate i have to modify to turn up the boost? thanks for helping me...
Old Dec 29, 2003 | 04:10 PM
pissedoffsol's Avatar
25 Year Member
Default Re: turn up the boost.... (kcjohnnyboy)
you need some kinda of boost controller... manual, electronic, or otherwise
Old Dec 31, 2003 | 10:05 AM
Default Re: turn up the boost.... (pissedoffsol)
can anyone else help me out? thanks...
Old Dec 31, 2003 | 10:07 AM
DC2R714's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">you need some kinda of boost controller... manual, electronic, or otherwise</TD></TR></TABLE>
He just told you.
Old Dec 31, 2003 | 10:16 AM
mike1114's Avatar
Default Re: turn up the boost.... (DC2R714)
go on ebay and buy a hallman manual boost controller or buy one used from someone. They are like 40 dollars.
I have a hallman and it works great, holds boost steady till redline.
swlabhot's Avatar
If you got $$$ get yourself an electronic boost controller like Apexi AVCR, if not, make yourself a 'Ball-Spring' type manual boost controller for next to nothing . Search on this here and u will find plenty on how to make one.
Old Dec 31, 2003 | 10:32 AM
RedTegLS's Avatar
Default Re: turn up the boost.... (swlabhot)
You can go up to 11psi but after that I think you will need a 3bar map sensor. Is it 11 or 14.5psi? Dont forget your fuel! In tank pump and bigger injectors!
Old Dec 31, 2003 | 12:52 PM
b16ahybrid's Avatar
Default Re: turn up the boost.... (RedTegLS)
Do you guy's really think you should be telling him how to raise the boost if he doesn't have a clue what he's doing? I can see it now..some guy that knows jack **** about what he's doing (deminstrated that by posting this topic) try's to run 15psi on his "stock" greddy kit......at least give him some knowledge on what he's about to do.....
to answer the question, you need either a manual boost controller (ball and spring) or electronic boost controller that will fool your wastegate.
But you have to make sure you provide more fuel for that extra air. I don't know much about the greddy kits, but i believe that your pretty much stuck with what they are set at or a few psi above that...anymore you''ll need an alternative form of tuning (hondata, hack,etc)..the believe the tuning device (blue/black box) cant compensate enough for the extra air. Unless you have the e-manage, then just retune....
more air + more fuel = more power
more air + same fuel = boom..
You also have to make sure your timing is in check. if your rigging it, retard your base timing via the distributor, or use a btm..stock timing + 10psi is not a good combo..
Scud
Apr 17, 2008 02:35 PM
chrisgottigsr
Dec 18, 2005 05:00 PM
5thGenCivicKid
Mar 26, 2005 11:40 PM
xxscaxx
Feb 21, 2005 04:13 AM
civicshowracing65
Feb 11, 2003 04:21 AM
