is this detonation?
Old Dec 29, 2003 | 07:20 AM
killerslp's Avatar
Default is this detonation?
the other night I was going home and decided to floor it to see how it felt(00 si greddy turbo, FMIC,5 psi) it was about 60 degrees car had been running for 5- minutes so it was full warmed up. I was in 3rd gear doing like 40, floored it. At about 7500 rpms I started hearing a noise like little tiny rocks hitting the underside of the car. I let off and tried it again, exact same noise. The next night same conditions I tried 1 last time and I didn't hear anything. to hear that noise I had my windows up and radio off and it was very faint. I am going to check the plugs this weekend but I would like to know if this is detonation, and if it is any clues on what could be causing it? using NGK Bkr7e's(not sure if the letters are right but their the common plugs everyone recommended for my setup) the injectors with the greddy kit and the blue box. As always I appreciate any and all replies, and yes I already did a search and found nothing useful on detonation.
Old Dec 29, 2003 | 07:31 AM
mopar junkie's Avatar
That could be detonation. I decribe it as marbles bouncing around in the engine. Check the plugs imediately after hearing what possibly could be detonation. If you see colored specles on the plugs then try to figure out whats causing the detonation.
Old Dec 29, 2003 | 07:37 AM
ek9vboi
Guest
Posts: n/a
holy ****! i have been hearing marbles since i got my car back!!! aHHHHHHHHHHHHHHH!!!!
this is really bad right? i dont think its do it anymore since i tuned with hondata. also, my spark plugs are all black...well around the ring part, not the middle. someone please help him and me shead some light?
Old Dec 29, 2003 | 08:20 AM
killerslp's Avatar
Default Re: (Mowin_LaWn_wIT_mY_HoNdA)
if I am not mistaken all black means the engine is running rich which isn't really a bad thing. if the black is wet as in oily then it is very bad.
Old Dec 29, 2003 | 11:36 AM
autoEXturbo's Avatar
Default Re: is this detonation? (killerslp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerslp &raquo;</TD></TR><TR><TD CLASS="quote"> At about 7500 rpms I started hearing a noise like little tiny rocks hitting the underside of the car.</TD></TR></TABLE>
You ever think it could of been just that. I know when i first went turbo every little thing i heard i became paranoid about. Also, with the greddy kit at 5psi you shouldn't have any detonation at all. I had it on my old motor at 8psi and didn't get detonation and that was with the greddy blue box and 93 octane.
Old Dec 29, 2003 | 11:39 AM
VTC_CiViC's Avatar
Default Re: is this detonation? (autoEXturbo)
It's a little coincidental that the sounds ONLY happens when he goes WOT don't you think?
Old Dec 29, 2003 | 11:47 AM
Default Re: is this detonation? (VTC_CiViC)
it could be, but I know that I don't hear much road debris hitting my car till i'm getting on it and my car doesn't detonate. It was just a guess.
Old Dec 29, 2003 | 11:52 AM
killerslp's Avatar
well I will see when I check the plugs this weekend, hopefully it's somthing else making the noise. I know the inner cv boot is leaking and spraying the grease all over, but I doubt it would sound like that.
Old Dec 29, 2003 | 12:10 PM
boostin b16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo &raquo;</TD></TR><TR><TD CLASS="quote">it could be, but I know that I don't hear much road debris hitting my car till i'm getting on it and my car doesn't detonate. It was just a guess. </TD></TR></TABLE>
you cant here much with open dp!
Old Dec 29, 2003 | 12:20 PM
ZoRG's Avatar
Default Re: (killerslp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerslp &raquo;</TD></TR><TR><TD CLASS="quote">if I am not mistaken all black means the engine is running rich which isn't really a bad thing. if the black is wet as in oily then it is very bad.</TD></TR></TABLE>
Doesn't unleaded fuel always burn black?
Old Dec 29, 2003 | 12:39 PM
FredoSP's Avatar
whats ur timing set at? Maybe you should adjust it to be EXTRA safe?
Old Dec 29, 2003 | 01:32 PM
killerslp's Avatar
Default Re: (ZoRG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZoRG &raquo;</TD></TR><TR><TD CLASS="quote">
Doesn't unleaded fuel always burn black?</TD></TR></TABLE>
well your plugs should really be black from a normal engine that isn't running rich. their obviosuly not going to be shiny clean, but they shouldn't be jet black either.
My timing hasn't been adjusted, and on a side note the temperature that I was hearing this at was alot cooler than it normally is down here, and I never noticed it before.
Old Dec 29, 2003 | 01:34 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: is this detonation? (FredoSP)
I have the EXACT same problem, but I'm running stock timing. Greddy kit, blue box, stock everything (pump, injectors, timing, clutch, fuel pressure, etc.) @ 7 psi. I'm going to retard it 2 deg. at the dist. and get some 7 series plugs vs. the 6 series I have now. Hopefully that will fix it.
Old Dec 29, 2003 | 01:56 PM
ZoRG's Avatar
My timing hasn't been adjusted, and on a side note the temperature that I was hearing this at was alot cooler than it normally is down here, and I never noticed it before.</TD></TR></TABLE>
Sorry, I didn't read the post porperly... Thought you were talking about the exhaust
Old Dec 29, 2003 | 02:21 PM
BoostedsiR's Avatar
Default Re: (ZoRG)
why dont you try to retard your timing.
Old Jan 1, 2004 | 06:30 PM
Default Re: (BoostedsiR)
bump...come on, I need to figure this out!
Old Jan 1, 2004 | 07:28 PM
Bailhatch's Avatar
Default Re: (boostincoupe)
Have you tried any of the suggestions given yet? Sounds like it is detonation to me. Colder air has more oxygen so if your fuel is based solely off boost pressure it will lean out more the colder the air. Try retarding the distrubuter 1 or 2 degrees, make sure your plugs are gapped right around .030".....
Old Jan 1, 2004 | 07:56 PM
killerslp's Avatar
Default Re: (Bailhatch)
actually I think my plugs are gapped at about 28 going by what everyone said before when I asked I took the average. I am going to check them sometime this weekend.
Old Jan 1, 2004 | 09:23 PM
psi420's Avatar
What you are describing is called "pinging".
And yes, it is mild detonation.
My car did the same, retarded a fe degrees and its gone.
Plugs showed barely and signs.
I even put them under a microscope.
Old Jan 1, 2004 | 11:16 PM
killerslp's Avatar
Default Re: (psi420)
just to ask before I look it up how do you adjust the timing?
Old Jan 2, 2004 | 08:24 AM
psi420's Avatar
You should not own a turbo vehicle if you do not know how to adjust timing.
Old Jan 2, 2004 | 09:14 PM
killerslp's Avatar
making a statement like that is like saying you shouldn't drive a car unless you know how to rebuild the engine. it was a simple question because it's not something that everyone does on a daily basis. I appreciated the advice you gave at first but your last post makes you seem like an ***. I figured it couldn't hurt to ask incase someone felt like quickly telling me before I find out for my self, noone knows everything before hand.
Old Jan 2, 2004 | 10:15 PM
HoNdAfReAk_13's Avatar
loosen the bolts for the dist. just enought for the distributor to move. you need a timing light. have the car runing point the light at the timing marks and you'll get a reading on the gun. if you turn the dist. towards the front of the car thats retarding the timing if you turn the dist. toward the fire wall then you are advancing the timing.
Old Jan 2, 2004 | 10:30 PM
FredoSP's Avatar
Default Re: (HoNdAfReAk_13)
any one know how much a timing light costs, any pics. I'm to lazy to look on google
Old Jan 2, 2004 | 10:51 PM
boredracer408's Avatar
Default Re: (FredoSP)
A timing light costs pretty cheap....
But an adjustable timing light goes from 70-and up. Of course there are different brands thats why theres different prices.
