Stock fuel pump capabilities? 11psi okay???
Re: Stock fuel pump capabilities? 11psi okay??? (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg »</TD></TR><TR><TD CLASS="quote">18g kit on a b18b
s200
lucas 440cc</TD></TR></TABLE>
Don't run stock pump. Use 255 lt/hr in-tank pump and get bigger injectors. Your s200 can control those big injectors.
s200
Re: Stock fuel pump capabilities? 11psi okay??? (porsche997)
I'm about to place a order for a 255 pump with lightningmotorsports. Which one should I get, the kit? High pressure?
the regular one and high pressure are all good. I use the regular one but a lot of people use the high pressure one. It's up to you.
Don't bother with hight pressure, you don't need it with the hondata and 440's...
High pressure is good with fmu but you will only need 40 psi fuel pressure and tuning. Too high pressure would also ruin your idle with big injectors...
turbolsvtecej1
09-07-2014 04:06 PM
HybridCoupe
07-06-2002 04:44 AM
