Compression too low what head gasket to help raise it?
b16 with 8.8:1 C/r I want to bring it up before putting on the turbo. Is there a headgasket I could buy or strip the stock one or something?
Re: Compression too low what head gasket to help raise it? (Boostage)
you can use like spoon thin gasket or remove the midde layer of stock gasket.
Re: Compression too low what head gasket to help raise it? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">you can use like spoon thin gasket or remove the midde layer of stock gasket. </TD></TR></TABLE>
Is it tricky to do? btw whats that like .3 point up?
remember when doing all this make sure you check your pistons to valve clearance. It does become tricky. i would just stick with the pistons you have and just boost more its makes the same pwer with a few more pounds of boost
