Dyno of SRT4 t3/t4e
Old Dec 31, 2003 | 07:25 AM
Blitzkrieg's Avatar
Default Dyno of SRT4 t3/t4e
Here is a dyno plot of our SRT4 with a Innovative T3/T4E 57 trim stg5 wheel .63 a/r. 2.5" borla exhaust, stock intercooler, stock 47mm throttle body, Turbo smart V port BOV, Turbo Smart wastegate, Mopar stg1 ECU/577cc injectors, our piggyback ECU, VP103 fuel and Sonoco 93 as a base plot
There are alot of restrictions in the system that will be addressed. We have a L/A intercooler, 60mm TB, and a Daryl *** head/cams. We are just taking steps to see what is doing what. Anyhow I figured I would share and see what input you folks have to offer. This is a great tech forum.
Old Dec 31, 2003 | 07:28 AM
RenoRacing's Avatar
Default Re: Dyno of SRT4 t3/t4e (Blitzkrieg)
Damn man! those are some good numbers that many of us would love to have! And with only some bolt ons, that's nice! I cant imagine the straw of a 47mm throttle body helps much!!! Good luck on the buildup. keep us up to date on how easy it is to get power from our domestic opponents.
jess
Old Dec 31, 2003 | 07:37 AM
DENCIO's Avatar
Default Re: Dyno of SRT4 t3/t4e (RenoRacing)
Good numbers . I wish I could boost that high
Old Dec 31, 2003 | 07:41 AM
Spooled1.6L's Avatar
Default Re: Dyno of SRT4 t3/t4e (mrdjay107)
I wish I could just crank it the hell up too. WEd have similar Hp numbers but there is NO WAY my car is 3000lbs screw that pig
Old Dec 31, 2003 | 07:42 AM
Ri5e's Avatar
Nice numbers, would've made more power with vtech y0!
Old Dec 31, 2003 | 07:45 AM
Blitzkrieg's Avatar
Default Re: Dyno of SRT4 t3/t4e (BG Boost)
HP is nice but I love the TQ. One thing I like about this plot is that it is almost a square motor (HP is the same as TQ) Another cool thing is that the pump peaks are the same RPMs as the racegas.
Old Dec 31, 2003 | 07:46 AM
Mr. Vapor's Avatar
keep in mind this is on a mustang dyno, so the #s are going to be slightly skewed from the normal dynojet. impressive none the less
Old Dec 31, 2003 | 07:47 AM
VTC_CiViC's Avatar
409lbs of torque.... must be a bitch to drive on the streets
Old Dec 31, 2003 | 07:56 AM
Blitzkrieg's Avatar
Default Re: Dyno of SRT4 t3/t4e (VTC_CiViC)
Typically the mustangs dyno lower than the dynojets that we have dynoed on before. This dyno is setup pretty reserve.
Also I really have to commend these Turbo Smart parts. These wastegates are dead on and the BOV sounds awesome and are extremely easy to adjust, just twist the top. There are no shims, tools, or disassembly needed
Old Dec 31, 2003 | 07:59 AM
Mr. Vapor's Avatar
really? Ive always been under the impression that the mustang dyno's yield higher #s than the Dynojets.
is the car streetable? or does it just spin and spin and spin
Old Dec 31, 2003 | 08:01 AM
jinxproof99's Avatar
New User
i loved watching that car run on drag radials last year. you guys need to look for more power. i want you to be a contender in the sportfwd class next year. and what kind of rev limit do you think you can get out of the car with some headwork/bigger turbo??
Old Dec 31, 2003 | 08:04 AM
Blitzkrieg's Avatar
Default Re: Dyno of SRT4 t3/t4e (Mr. Vapor)
The car us very streetable. We just got back from a 1k mile round trip and averaged 27mpg.
Old Dec 31, 2003 | 08:07 AM
Blitzkrieg's Avatar
Default Re: Dyno of SRT4 t3/t4e (jinxproof99)
Well we are going to work with Daryll *** on the rev. I would like to see at least a 7500rpm, but it all depends on how Daryll tunes the head and cams.
Old Dec 31, 2003 | 08:31 AM
gdrum's Avatar
thats crazy power outta just those few upgrades...wow im impressed
Old Dec 31, 2003 | 09:49 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blitzkrieg &raquo;</TD></TR><TR><TD CLASS="quote">Well we are going to work with Daryll *** on the rev. I would like to see at least a 7500rpm, but it all depends on how Daryll tunes the head and cams.</TD></TR></TABLE>
I think with the head work and larger throttle body you will see greatly improved numbers.
Old Dec 31, 2003 | 10:30 AM
rocket256's Avatar
That is some outrageous torque!!!!!!
Old Jan 1, 2004 | 05:51 AM
Boostfed's Avatar
New User
That is just AWESOME!!!!!!!!!!!! Props! I am SKERD though for Sprot FWD next year when all these High HP/Torque SRT-4s come out. I couldn't believe how small the stock TB was 47mm, hehehe cute like a DX or VX TB on a Honda Civic. Big restriction there IMO. Good #s though!
Old Jan 1, 2004 | 06:50 AM
blueturboteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">really? Ive always been under the impression that the mustang dyno's yield higher #s than the Dynojets.</TD></TR></TABLE>
Yeah they actually read quite a bit lower. THey are said to be much closer to real #'s and to be more repeatable as well.
Old Jan 1, 2004 | 07:32 AM
TruePlayaz114's Avatar
Default Re: Dyno of SRT4 t3/t4e (blueturboteg)
i'm definetly buying a srt-4 next month
Old Jan 1, 2004 | 07:37 AM
RacerStev's Avatar
Nice numbers for a basicly stock engine! Are you sure the rpm is accurite? When
I dynoed my Neon at AWE the rpm's were about 1000 off compared to my data
log on the standalone. I think yours use's the same wasted spark ignition setup
as my first gen does.
BTW, I have a basicly stock head with a backyard P&P, my power peak is closer
to 7500. You need a set of cams for this puppy!
Also, I've been told to figure in between 5 and 10% more hp to get close
to a comparable dynojet hp figure. SO I'd guess you are closer to 425-435 hp.
Have you tryed anyone else in the area for dyno time? Think I'm gonna go to
this place,
http://xoticmotorsports.com/
The price is less then half what AWE charges.
Steve
97 Neon Auto, SFWD
Old Jan 1, 2004 | 07:54 AM
alpha's Avatar
When are you going to be able and get some times down at the track?
Old Jan 1, 2004 | 08:28 AM
Tinker219's Avatar
Default Re: Dyno of SRT4 t3/t4e (0x64)
Soon as the shop is finished, expect a nice SC61(if it doesnt sell) to be residing in the engine bay of my shop car.
Stage 1 will have to come first, but Im expecting around 300whp by just bolting the turbo, SST manifold, and 4" DP/exhaust on with the stock computer. Add Stage 1, and who knows. I do know that the Stage 1 upgrade works REALLY well w/heavy modifications
Old Jan 1, 2004 | 09:13 AM
Rhman19's Avatar
Default Re: Dyno of SRT4 t3/t4e (Tinker219)
I thought you said it was going to remain stock tinker.
Old Jan 1, 2004 | 09:17 AM
HXMan's Avatar
Default Re: Dyno of SRT4 t3/t4e (Rhman19)
Stock Sucks.
Old Jan 1, 2004 | 09:20 AM
alpha's Avatar
I would love to see an SC61E or a GT35E on an SRT-4 &gt;=]
