how to prevent boost creep on t25?
Old Dec 29, 2003 | 08:13 PM
ZCHF's Avatar
Default how to prevent boost creep on t25?
I have a zc with a homemade trubo setup and was wondering how i can keep it from spiking to 12 psi and throwing a check engine light. i cant go wot because it overboosts and floods the engine. please help
thanks
brian
Old Dec 30, 2003 | 02:31 AM
pissedoffsol's Avatar
25 Year Member
Default Re: how to prevent boost creep on t25? (ZCHF)
whats the wastegate set at? sounds like its too high in the first place.
other option is more ceck valves....
Old Dec 30, 2003 | 02:43 AM
turb's Avatar
Default Re: how to prevent boost creep on t25? (pissedoffsol)
how bout a manual boost controller?
Old Dec 30, 2003 | 05:05 AM
25 Year Member
Default Re: how to prevent boost creep on t25? (turb)
boost controller only goes up- not down.
Old Dec 30, 2003 | 01:20 PM
ZCHF's Avatar
yeah, boost controllers only go up, but anyway i believe the stock mitsu t25 is actuated at 8 psi and it creeps all the way to 12. i need to get it down to be safe but really dont know how.
Old Dec 30, 2003 | 01:24 PM
psi420's Avatar
What is your exhaust diameter?
Old Dec 30, 2003 | 01:29 PM
igotyofire's Avatar
Default Re: (psi420)
my friend has the same problem on his stock mitsubishi eclipse he put an exhaust on it and it spikes up to like 20-22lbs
Old Dec 30, 2003 | 01:46 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">boost controller only goes up- not down.</TD></TR></TABLE>
cant u just put a check valve with a manual valve on the wastegate line... that way u can turn it enough for some boost to go and lower the boost
Bailhatch's Avatar
Default Re: (igotyofire)
If you have an internal WG it might help to port it out so it can bypass more around the turbine. Even a MM or 2 will greatly improve the flow. oh and it's free
Old Dec 30, 2003 | 03:19 PM
ZCHF's Avatar
Default Re: (Bailhatch)
yeah, that sounds like a good idea. I have a 2.5 inch dp and 2.5 inch turbo back exhaust w/o cat. i think it flows so well that it draws more boost. oh yeha. i dont think that i can use a check valve sense im running the smc which reads the map sensor thus if a check valve was used, i would read less psi and not compensate fuel accordingly and i would run lean, and i dont think that i want to run lean at 12 psi on a stock zc. any other ideas on how to prevent it for boost creeping? thanks guys
brian
Old Dec 30, 2003 | 03:52 PM
psi420's Avatar
Try adding a CAT and see how it does.
Or like the other guy said, port the wastegate port out some.
I think your exhaust is flowing more than your wastegate can keepup with.
Same problem with external wastegates and open DP
Old Dec 30, 2003 | 04:44 PM
ZCHF's Avatar
thanks
ill try some of those things.
hopefully something will work
thanks again
Old Jan 6, 2004 | 02:14 AM
phresh_5's Avatar
Try tapping the wastegates vacuum line on the intake manifold instead of the compressor housing.
boosted 95 coupe
Aug 23, 2006 01:36 AM
xxscaxx
Feb 21, 2005 04:13 AM
95excoupe
Apr 13, 2004 03:44 PM
Meet07
Feb 3, 2004 10:45 PM
crx1856
Jun 10, 2003 08:38 AM
