Some sohc swap pics =P
I pretty much stay in this forum so I'll post this here. It's FI related Like 2 thursdays ago we did the swap. I didn't expect it to take as long as it did. We started pulling the cx motor at about 6pm and it took until 5am the next morning before the z6 was in and ready to fire
I don't know where I would be without InfamousRS. He put in a lot of hours assembling the motor, not to mention all the help he has given me.
The D16Z6 has
-CP 75.5mm pistons
-Eagle rods
-All new OEM essentials
-ACL Bearings
-Posted block with stock sleeves
-JDM D15b LSD trans(I love having short gearing again )
-ACT XTSS clutch
-ARP headstuds
InfamousRS has the better camera so he has all the build pics Here are a couple though..
Beefy pistons!
InfamousRS puttin the motor together
Me pulling the mount bolt
Out comes the cx motor!
The SOHC hotness is in
I put the t belt cover on right after I took the pics(I don't like running without one) Also the compression number is still on the valve cover from the junkyard, lol. I need to scrub it off.
Again, thanks to InfamousRS and the 2 others that helped me with the swap. Upon first start up, the motor was knocking loudly. We thought maybe the machine shop bored the block wrong causing loud piston slap.. So we pulled the entire head back off, measured some things and pulled a piston out. We slapped everything back together and it ran like a champ. Turns out the timing belt was off one tooth, and the fact that we held the cx disi up for startup. The ex distributor I bought was bad so we just wanted to hear it start. Lesson learned though
The motor has about 150 miles on it and running great. We did the rough break in. The motor pulls! The compression is higher than 9:1 since the pistons are out of the hole a bit. I'm hoping to break 300whp but who knows. Turbo kit is going on soon. My fingers are tired. thanks for loooking
Modified by 5thgencivic at 6:41 PM 12/30/2003
The D16Z6 has
-CP 75.5mm pistons
-Eagle rods
-ACL Bearings
-ACT XTSS clutch
-ARP headstuds
Beefy pistons!
Re: Some sohc swap pics =P (SPOON_BeIgHtEeNsEe)
http://www.hmotorsonline.com It was like $420 shipped..
Re: Some sohc swap pics =P (QUICKERSILV3R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUICKERSILV3R »</TD></TR><TR><TD CLASS="quote">SOHCs own!
for you and a good motor and tranny</TD></TR></TABLE>
just cause yours smokes doesn't mean it owns the only thing your car owns is the ozone layer!
it never seems to amaze me, maybe you might comprehend a dohc one day
Re: Some sohc swap pics =P (BoostedsiR)
NINJA POWAH!!!
i think i may have to look into one of those trannies. mine is broken again.
it will always works good if the builder is drinking some good Dutch Heineken Bier :D
sorry im dutch so i always see those things. looks nice.. ill hope you get some good #'s with that setup.
Re: Some sohc swap pics =P (underrated)
I am pretty sure the gearing is the same as the USDM d-series ex tranny's. However it feels shorter, but I think it's just because I haven't drove with an ex tranny in a while. Cruising at 60-65mph it's at about 2700 rpm or so.
Re: Some sohc swap pics =P (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">How long till turbo is on??? What turbo setup are you gonna run?</TD></TR></TABLE>
Turbo will go on as soon as I get the money to afford tuning, lol. Also the back door on the intercooler has to be re-done(doesn't line up with turbo) and quite a few things welded. The setup consists of:
-Lovefab SST
-Spearco 24x8x3 cooler with backdoor
-Greddy type-s bov mounted on intercooler
-T3/T04e 50 trim .63
-tial 38mm gate
-3" dp, 3"cat, 3" straight pipe exhaust
-Hondata S200b with AEM FPR, Walbro intank 255 and rc 550cc saturated injectors
-Turbo xs dual stage boost controller(I'm hoping it doesn't spike..)
I'll probably run 8psi daily, and 1 bar and the track and sometimes on the street. I'm praying the sleeves and clutch will hold. With a good tuner I know the sleeves will. They better anyway
-Lovefab SST
-tial 38mm gate
Re: Some sohc swap pics =P (Buraku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku »</TD></TR><TR><TD CLASS="quote">you dont live with any women do you?</TD></TR></TABLE>
Hehe, the motor was assembled and swapped in over at InfamousRS' house. but no I do not
Re: Some sohc swap pics =P (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">
Hehe, the motor was assembled and swapped in over at InfamousRS' house. but no I do not </TD></TR></TABLE>
haha! I dont live with any women...My girlfriend doenst like to cook in my kitchen though when I build motors in it
Swipe'd
06-12-2007 10:21 AM
tegasaurus
26
05-21-2003 12:21 AM
