? about converting a mani w/t3 flange to t4
Re: ? about converting a mani w/t3 flange to t4 (d98clturbo)
yeah, the easiest way would be to weld the new flange directly over the old one. Check for clearnce issure before you make anything permenant.
Re: ? about converting a mani w/t3 flange to t4 (boostn420)
You could weld directly to the other flange as mentioned or you could get another t3 flange and a t4 flange and make a 1" long piece of rectangular or round steel that has a flange welded to each end, then bolt it all together. Just an idea if you didn't feel like permanently modding your manifold. plus you could then clock your turbo to where you need for clearance.
