my new turbo parts! (lotsa pics)
Old 12-30-2003, 12:45 PM
superstud's Avatar
Default my new turbo parts! (lotsa pics)
i've collected a bunch of stuff for my custom turbo kit so far, and i have a few problems that i need help with... pics included!!!
a) solved!
b) solved!
c) can't get the internal wg housing off the turbine housing. its got some kind of blue gasket maker, and i can't pry it apart! any suggestions?
d) compressor housing is only held on by one 3-bolt bracket, not two. is this ok? should i get another one? where?
i want to do the install in about a month so i gotta get these things sorted out asap. please help!!! thanks
Modified by superstud at 2:58 AM 12/31/2003
Old 12-30-2003, 12:48 PM
rjardy's Avatar
Default Re: my new turbo parts! (superstud)
That ring is not a fire ring, it seats the wastegate, install it with the ridge facing up into the wastegate. It will not sit flush but will once you bolt it down. It seats the wastegate and prevants it from leaking.
Rob
Old 12-30-2003, 12:52 PM
IHaveTurbos's Avatar
Default Re: my new turbo parts! (rjardy)
Yes there are different sizes on the turbos, there is the Ford 5 Bolt turbine side which is the smaller, and the Mercedes 5 Bolt (the one you have) which is bigger I carry both Flanges laser cut.
Tim
Old 12-30-2003, 12:59 PM
DRAGLS's Avatar
Default Re: my new turbo parts! (Hyundai4G63T)
open up the holes a little
Old 12-30-2003, 11:56 PM
superstud's Avatar
bump, please help
Old 12-31-2003, 02:52 AM
youngkow's Avatar
C) take off the exhaust housing, and try baking it in the oven if it is a silicone based sealer.
D) Yes you definitely need the other bracket thing. You can get one from http://www.majesticturbo.com
Old 12-31-2003, 12:35 PM
superstud's Avatar
well i figure if the blue stuff will hold up under 1600* heat then a 500* oven isn't going to do a whole lot to soften it up. any other ideas?
Old 12-31-2003, 01:27 PM
kranked91dx's Avatar
for your blue gasket stuff, try slicing a Razor blade between the housing and the blower, that should work prety nice, if the stuff is too tough then I don't know.
for shure I know this trick worik with Mr. Gasket Orange Gasket maker, but I don't know this blue stuff.
hope this Help
Kranked
Old 12-31-2003, 11:39 PM
superstud's Avatar
nope, razor blade didn't work. actually the blue stuff is pretty soft. i thing i'll just try hitting it with a hammer! its friggin pissing me off.
Old 01-01-2004, 06:56 AM
92HB_HB's Avatar
Default Re: (superstud)
must have bought it used... why the heck was one of the brackets missing??? that's like buying a car and only getting 3 doors instead of 4 or something.. I would be MAD....
Old 01-01-2004, 09:46 PM
superstud's Avatar
well i got the internal wastegate off today just by givin'er with a hammer and chisel. i was scared it would crack but thank god it didn't!!
thanks for all the help guys!!
chevellion
08-12-2008 12:41 PM
dizzyek
10-31-2006 04:34 PM
95BlkGSR
08-17-2006 12:02 PM
TurboSedan
12-28-2001 11:46 AM
Quick Reply: my new turbo parts! (lotsa pics)
