Let's see your dumptube pictures
alright guys, let's see em. Im looking for ideas on how to run mine. running a lovefab mani with WG comin off to passengers side... lookin for a creative way to run it or just down and away will do. also runnin a tial38mm but shouldnt matter.
show off your shiz...
also: (offtopic) you think this WG position will creep? i might be trading wastegates to a lower spring rate as a safety net...but i dont know, shouldnt it be in the middle?
Re: Let's see your dumptube pictures (RedStarGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedStarGsr »</TD></TR><TR><TD CLASS="quote">
also: (offtopic) you think this WG position will creep? i might be trading wastegates to a lower spring rate as a safety net...but i dont know, shouldnt it be in the middle?</TD></TR></TABLE>
Looks like it might creep in higher rpm's since its not right over the turbo.
where are you guys buying this piping, and what size should be used? i assume a bigger sized pipe will allow all exhaust fumes to be released without any strain...
Re: (RedStarGsr)
summitracing.com has them. I usully use 1 3/4" because it seems to be what I have at the time. anything over 1.5" would work fine, not too much is flowing out of it.
http://store.summitracing.com/...12550
i cleaned up both sides with a big wire wheel...but couldnt get the middle. that is whe i first got it and cleaned it up, before it got clocked and added all the little parts (ic pipe, air filter part, downpipe flange)
Re: (Muckman)
Mine is like that and it looks like it will hit but if you close it and reach from under the car (when installing it), mine has about 1/4"~1/2" inch clearance left. I think most people are runnig it like this.
Re: (Boofster)
http://www.burnsstainless.com has materials as well. My dump is at the welders getting welded now..
Re: (AzSiRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSiRacer »</TD></TR><TR><TD CLASS="quote">Here is mine. Sorry for the huge picture. By the way, it is all for sale. Im me if interested.
Baller
Here's mine:
It dumps onto, but not in the Downpipe.
Baller
Here's mine:
Moderator in Chief
Re: (Cyphear)
Im using an elbo to put my Tial wastgate on its side, otherwise it hits my hood. But the exhaust of the wastegate points right at my revhard manifold and turbo below. What a shity design. I dont think I can even get a dumptube in there because the manifold is directly below.
Re: (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE »</TD></TR><TR><TD CLASS="quote">heres mine
Home Depot Racing
Home Depot Racing
Re: (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster »</TD></TR><TR><TD CLASS="quote">Here's mine :
That isnt really your car, is it??
Dumptube?? Whats that?? LOL. Engine block all black from wastegate, I need one though.
Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
Kinda OT but how did the center of your turbo get so rusted compared to the compressor and exhaust housings???</TD></TR></TABLE>
Its called heat!
Chris
Its called heat!
Chris
