200-250 whp on a d16z6 sohc turbo?
I have a friend in cali that just spent 6000 on a b16a2 built for n/a and he only putting down around 200whp. well i was gonna follow his footsteps but go turbo. now im having a little money trouble and i was thiking of going sohc turbo. i have heard stories of people making 300+hp on a sohc and my question is at the least could i make 200whp on a greddy sohc setup?
Re: (danl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danl »</TD></TR><TR><TD CLASS="quote">You can make 300whp easy on a d16, pump gas.</TD></TR></TABLE>\
stock internals too?? what is a recommended psi on thje stock internals?? i was hearing ranges from 7-12... whats the compression? and oh yea, is that a greddy kit or can i make the same on a homemade turbo kit?? something like a dsm t25 or something like that 14g
Re: (Taffeta_EXcpe)
well im not sure if you plan on beating him but your gunna need more than 200whp turbo to beat his 200whp all motor.
and im sure if you peaced a turbo kit together you can get equal if not more power. it all depends on quality of products that you buy. small t25 great spool time but high end will suffer a little. id get like a 16g. not too big but big enough. good luck
EDIT: and whats the most power a d16z6 can make on stock internals?
Re:
Daym! You guys are making over 200hp at 10psi GReddy?! Tha is really impressive! Mine only pulled 166whp and 175wtq.....UNTUNED.... I'm using the AFC "hack" with DSM 450cc's on stock internals. I think I will hit 200whp once I get it tuned on the dyno.... but I have to get my clutch replaced first. Goodluck to everyone's project
Re: (Taffeta_EXcpe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taffeta_EXcpe »</TD></TR><TR><TD CLASS="quote">\
No, not stock internals.
Re: (danl)
Im' about to go with a greddy turbo kit myself, And i will be happy with about 175 whp with a z6 turbo daily driver. (new to fi world ).
To the greddy kit. heard nothing but good things about it and it's decently priced.
Or you can go custom!!!
Re: (mitsuman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman »</TD></TR><TR><TD CLASS="quote">well im not sure if you plan on beating him but your gunna need more than 200whp turbo to beat his 200whp all motor.</TD></TR></TABLE>
sohc turbo torque owns...
I wanna boost my 93 Si too (d16z6), but it's got some clicks on it..200K's, would it really be a problem? The internals are getting on with age I guess, but you wouldn't be able to tell driving the car, smooth as brand new....What would you guys recommend???
Plus Greddy Kits run for around 2500-3000USD right??
I've quit using this account
Re: (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog »</TD></TR><TR><TD CLASS="quote">I'm running a d16y7 @10.3psi on the greddy kit and made 203whp stock internals. D series make real nice tq</TD></TR></TABLE>
what turbo ? 15g or 19t?
Whoever says D series internals cant hold boost needs to do some more researching. There has been more than a handful of people on this board and others making 250-300 whp on stock d series motors. The sleeves have been proven to hold the same boost as b-series, its just the rods that are slightly weaker. I personally plan on pushing my d15b vtec to atleast 270 whp with a completely stock motor. I'd say dont boost past 15lbs, thats my rule of thumb atleast, highest ive seen on a stock D series has been 17psi which yeilded a little over 300 whp, completely stock motor and head
Re: (llewsirc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc »</TD></TR><TR><TD CLASS="quote">
what turbo ? 15g or 19t?</TD></TR></TABLE>
15g
15g
Re: 200-250 whp on a d16z6 sohc turbo? (blkeg)
I don't know that much about turbo yet. I am saving to get a kit for my 96 ex coupe. What else besides the stuff that comes with a kit (blow-off valve, wastgate, intercooler, etc.) would i need to get to push 200whp on stock internals? Would apprieciate everyone input.
Re: 200-250 whp on a d16z6 sohc turbo? (civic_6991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_6991 »</TD></TR><TR><TD CLASS="quote"> I don't know that much about turbo yet. I am saving to get a kit for my 96 ex coupe. What else besides the stuff that comes with a kit (blow-off valve, wastgate, intercooler, etc.) would i need to get to push 200whp on stock internals? Would apprieciate everyone input.</TD></TR></TABLE>
You will need some type of engine manegment like hondata. An upgraded fuel pump and some 440 cc injectors.
Re: 200-250 whp on a d16z6 sohc turbo? (norcalcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx »</TD></TR><TR><TD CLASS="quote">
You will need some type of engine manegment like hondata. An upgraded fuel pump and some 440 cc injectors.</TD></TR></TABLE>
Doesn't the Greddy kit come with fuel injectors and a fuel management system?
Re: 200-250 whp on a d16z6 sohc turbo? (koreanwilcox)
THE 96-00 kits come with 310 injectors and the emanage.
EDIT: and whats the most power a d16z6 can make on stock internals?</TD></TR></TABLE>
What makes 200 whp n/a faster than 200whp forced induction? Its all power to weight ratio. if a n/a car is lighter than a turbo car and makes the same power.. the n/a car will be faster (not taking into consideration traction and other factors). On the jg engine dynamics website (i dont know if its still up) there was a d16z w/ a jackson racing supercharger making 200whp that ran 11s.
I ran a sohc turbo a while back. D16a block, LS rods w/ arp rod bolts. srp pistons, blockguard, fmu, 370cc inj.= 265 whp. @19 psi. Same setup with speed pro management, 550cc inj. = 308whp. @ 29psi.
