C16 really needed? Will 110 be enuff?
Old Dec 31, 2003 | 06:50 AM
PM-Performance's Avatar
Default C16 really needed? Will 110 be enuff?
Was just curious becuase i was starting to get prices on race gas, i can prob get c16, but at a considerablly higher cost from what i saw and harder to get. not readily avail like the Cam2(110)
i can get cam2 for $5.40 a gallon for smaller amounts and like $5.10 a gall for drums.
would 110 be enuff to support some insane HP without detonation .
my motor is about 9.0-9.3:1 in that range abouts.
What you guys think.
Old Dec 31, 2003 | 06:53 AM
Boostfed's Avatar
New User
Default Re: C16 really needed? Will 110 be enuff? (itr206)
What boost and power levels are you expecting? If you have lower octane then you would want less timing in the tune, if you get higher octane you can advance the timing more and possibly get more power from it. My local race shop has had tests of pumpo gas to 116octane of somewhere around 20whp really.
Old Dec 31, 2003 | 06:58 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: C16 really needed? Will 110 be enuff? (Boostfed)
trust me, vp c16 is worth the money. I ran some other **** and it was complete garbage
Old Dec 31, 2003 | 07:14 AM
Default Re: C16 really needed? Will 110 be enuff? (SIXTYdashONE)
ok that will do it then , boost levels im not sure, but i wanna eventually be in the 600's
Old Dec 31, 2003 | 07:17 AM
quickda6's Avatar
600? throw some 94 in that biatch
Old Dec 31, 2003 | 07:21 AM
Default Re: C16 really needed? Will 110 be enuff? (quickda6)
94 will be for the streets and to get me to the track , hmmm wonder if i can go 30psi with 94? lol.
Old Dec 31, 2003 | 07:22 AM
XXXRacing's Avatar
Stick with C16. If you look hard enough, you should be able to find it in bulk for around $7.00 a gallon. Brian
Old Dec 31, 2003 | 07:25 AM
Default Re: C16 really needed? Will 110 be enuff? (XXXRacing)
is it safe to keep **** like that in bulk? i dunno people used to always tell me to keep an eye on stuff like that becuase 55 gallons of c16, something happens, there will be qwuite a crater where my garage and racecar once were.
Old Dec 31, 2003 | 07:30 AM
30psi Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">is it safe to keep **** like that in bulk? i dunno people used to always tell me to keep an eye on stuff like that becuase 55 gallons of c16, something happens, there will be qwuite a crater where my garage and racecar once were. </TD></TR></TABLE>
C16 really isnt anymore unstable than regular fuel. The only thing I would recommend doing if you have a 55gal drum is to bleed off the air vapor inside the drum every so often so pressure dosnt build up in there and keep it out of sunlight.
Old Dec 31, 2003 | 08:23 AM
Default Re: C16 really needed? Will 110 be enuff? (30psi Teg)
thats a good idea. hmmm , amybe ill look around and see what i can find then ,
thanks for the help guys.
Old Dec 31, 2003 | 11:39 AM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">is it safe to keep **** like that in bulk? i dunno people used to always tell me to keep an eye on stuff like that becuase 55 gallons of c16, something happens, there will be qwuite a crater where my garage and racecar once were. </TD></TR></TABLE> why would you care you wouldnt know anything about it
Old Dec 31, 2003 | 12:48 PM
gitwidit's Avatar
Default Re: C16 really needed? Will 110 be enuff? (h22 civic)
Average price around here is $45 for 5 gallon drum of C16, well worth it if your doing a race gas tune. Has a heavier specific gravity than most other race fuels.
Old Dec 31, 2003 | 08:36 PM
h22 civic's Avatar
tt
Old Dec 31, 2003 | 11:36 PM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psi Teg &raquo;</TD></TR><TR><TD CLASS="quote">
C16 really isnt anymore unstable than regular fuel. The only thing I would recommend doing if you have a 55gal drum is to bleed off the air vapor inside the drum every so often so pressure dosnt build up in there and keep it out of sunlight.</TD></TR></TABLE>
I agree. Actually it would be alot less volitle (sp?) than regular gas cause of the high octane rating. I wouldn't worry about storing it.
Old Jan 1, 2004 | 04:38 AM
QCKGSR's Avatar
Default Re: C16 really needed? Will 110 be enuff? (Kwuaymaikrup)
i run torco 118 NOS+ that stuff is awsome, costs me 10 a gallon
Old Jan 1, 2004 | 05:10 AM
Default Re: C16 really needed? Will 110 be enuff? (QCKGSR)
thats nice toknow, people were telling me to keep an eye on the pressure build ups and such like mentioned above.
Old Jan 1, 2004 | 07:42 AM
Muckman's Avatar
Moderator in Chief
so where do you get C16 anyways?
Old Jan 1, 2004 | 08:56 AM
gitwidit's Avatar
Default Re: C16 really needed? Will 110 be enuff? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">so where do you get C16 anyways?</TD></TR></TABLE>
Any authorized VP race fuel distributor.
Old Jan 1, 2004 | 10:06 AM
h22 civic's Avatar
ny=bay cycles bronx n.y ask for joe
blackeg
Jul 9, 2011 06:03 AM
kornerk12
Jan 29, 2006 06:53 PM
.RTErnie
Aug 18, 2005 12:20 PM
shadowdawn
Nov 6, 2002 10:45 AM
ZUL8R
21
Oct 20, 2002 11:59 AM
