what else do i need for hondata?
Old Dec 29, 2003 | 03:12 AM
integracivic94's Avatar
Default what else do i need for hondata?
Just double checking i have a d16z6 and want to turbo it! i am planning on using hondata! what do i need apart from the base and the boost option??? any help appreciated!
Old Dec 29, 2003 | 03:17 AM
pissedoffsol's Avatar
25 Year Member
Default Re: what else do i need for hondata? (integracivic94)
proper ecu socketed for the rom, and a tuner with dealer-level software, larger injectors
Old Dec 29, 2003 | 09:22 AM
dabrown's Avatar
Are you going to have it tuned for you?
Old Dec 29, 2003 | 10:45 AM
Default Re: what else do i need for hondata? (dabrown)
planning on having it tuned by someone else! apparently rx7 injectors will work! just need slightly modifying to fit!!!! do i get saturated or peak and hold???
Old Dec 29, 2003 | 10:49 AM
g2turbo's Avatar
either saturated or peak and hold will work, i dont know about the rx7 injectors though. I suggest if you plan on keeping the car, get some 550's and those should be fine unless you are going over 350 whp. If you go any smaller you will most likely have to buy injectors more than once.
peak and hold injectors require a resistor box.
Old Dec 29, 2003 | 11:25 AM
Default Re: what else do i need for hondata? (g2turbo)
i would eventually hope to hit between 350/400bhp!!! dont i have to add some sort of resistors for peak and hold? what injectors are better saturated or peak and hold? it was on ht i read i could use rx7 injectors- this is what i found
 Mazda RX7 injectors can be used with 92-95 Civic!!!
« on: November 09, 2003, 09:30:00 pm »
Hey, I just wanted you guys to know that 88-90 RX7 injectors can be used with 92-95 Honda Civic. Since they are also high impendence, no resistor box is needed. It's basically plug and play. It also plugs right up to my existing Honda Civic injectors harness without cutting them.
It has a little keyway slot that interfers with the factory honda plug. This is a real simple fix, just get a razor blade and cut the little tab right out so the plug snaps on nice and tight. These are not actual pictures of the RX7 injectors. These of course are the bluetop DSM injectors but same idea.
The seals have to be modified a bit so these injectors will fit properly, very similar to the DSM injectors.
****, i should have taken pictures.
Check the numbers on the side of the injectors to see what type of injectors you got.
1984-85 RX-7 195500-0900 Peak and Hold 460cc Orange Top
1986-87 RX-7 195500-1350 Peak and Hold 460cc Red Top
1986-87 RX-7 195500-1370 Peak and Hold 550cc Tan Top
1988 RX-7 195500-1350 Saturated 460cc Purple Top
1988 RX-7 195500-1370 Saturated 550cc Purple Top
1989-91 RX-7 195500-2010 Saturated 460cc Red Top
1989-91 RX-7 195500-2020 Saturated 550cc Purple Top
1993-up RX-7 Twin-Turbo Saturated Primary 550cc Secondary 850cc
Try it!
Any questions email me: JDMEG6SiR@yahoo.com
Old Dec 29, 2003 | 12:00 PM
bump
Old Dec 29, 2003 | 03:47 PM
g2turbo's Avatar
if you plan on 350-400 down the road then i would purchase 720's. These are still very idleable (is that a word?) hehe, and you wont have to buy injectors twice. I started out and bought 550's which were perfect for what i was making, and now im buying 1000's
between peak and hold vs. saturated... i dont think either is better, but in most cases, saturated are only availabe in smaller sizes. the largest saturated injector i know if is a 550 offered by RC and Rochester.
Old Dec 30, 2003 | 06:49 AM
thanks for the reply's!!!! what did u think to the rx7 injector guide do u think these are possible are is it just bs???/
TokuiAutowerks
Jun 19, 2008 06:02 PM
96redgsr
Jul 21, 2004 09:46 PM
Hoodwinked
Aug 23, 2003 12:32 AM
civcexcoupeblack
Dec 16, 2002 01:16 PM
PM-Performance
Nov 4, 2002 08:40 AM
