some Boost Suspension Q's???
Old Dec 30, 2003 | 04:18 PM
JDEM1's Avatar
Default some Boost Suspension Q's???
Okay, first off I have a 2000 civic si boosted with a custom kit, making 240ish whp @ 6.5psi. I'm running ground control coilovers with stock shocks.
-My question is, why is it that when i run my car hard.. shifting WOT at redline, instead of spinning tires, chirping, etc.. my car just feels like it hits hard and gets excessive wheel hop? , i would have thought the tires would spin, but is it my shitty suspension that is making it feel this way?. It feels like my car is going to snap in half, any input thats not a negative remark is appreciated, thanks in advance.
Modified by JDEM1 at 2:20 AM 12/31/2003
Old Dec 30, 2003 | 05:20 PM
JDEM1's Avatar
Default Re: some Boost Suspension Q's??? (JDEM1)
oh c'mon no advice?
Old Dec 30, 2003 | 05:24 PM
gritsak's Avatar
stock shocks prolly arent helping...you can also look into traction bars. my friends civic with comp. engineering bars had no wheel hop at all with close to 400whp...he also has full koni coilovers too.
Old Dec 30, 2003 | 06:29 PM
lazerus's Avatar
Default Re: some Boost Suspension Q's??? (gritsak)
trac bars will definately rid you of the wheel hop, perhaps your suspension height settings (of course along with the dampers) could be changed to minimise/eliminate Wheel hop, what is your F/R coilover settings ?
Old Dec 30, 2003 | 07:33 PM
Bailhatch's Avatar
Default Re: some Boost Suspension Q's??? (lazerus)
it's probably 95% your shocks. Get some illuminas or AGXs in there then see if you need other parts
Old Dec 30, 2003 | 10:36 PM
JDEM1's Avatar
Default Re: some Boost Suspension Q's??? (Bailhatch)
i hope its the shocks!, so when i get my teins in it will be fine.. thanks for the advice guys..
Old Dec 30, 2003 | 11:55 PM
evosol's Avatar
Have you checked out your motor mounts lately? they could be fatigued or cracked/ripped. While doing poly bushings in my car i noticed that the stock rubber bushings on the front lower control arm can and does have lateral movement (like when hard launching) adding to the wheel hop effect.
i'd recomend making your own polly motormounts to anyone. look it up on homemadeturbo.com works awsome!
jwest1150
29
Oct 11, 2011 07:25 PM
lewdude
Suspension & Brakes
21
Feb 23, 2005 06:55 PM
HRDCORD
Dec 9, 2003 07:23 AM
cjames235
Feb 26, 2003 06:10 PM
Adampops
Dec 15, 2001 05:51 PM
