Clearance probs with oilpressure sending unti after Endyne catch can install . Help
Old 12-27-2003, 06:47 PM
PM-Performance's Avatar
Default Clearance probs with oilpressure sending unti after Endyne catch can install . Help
I put the Endyne catch can in the block and the ports kinda get in the way of the Autometer oil pressure sending unit i was using. too little space between the filter and the ports. Could i use a Sandwich adapter to fix this ? like one port for the feed line and the other prot for the pressure sending unit ? would i have clearance probs?
or is there any place else i could tap into and get a good pressure source?
Old 12-27-2003, 09:16 PM
Bnjmn's Avatar
Default Re: Clearance probs with oilpressure sending unti after Endyne catch can install . Help (itr206)
Did you put the pressure sender right into the block? In any case, the best thing to do is to run a 1/8" BSPT to 1/8" NPT adapter into the block, then run a line from the block to a "t" mounted on the firewall. You can then screw the pressure sender into the T and also have an oil line available for the turbo as well on the other end of the tee fitting.
You will also never have any problems with the brass on the sender hardening and then breaking.
It is something of a pain to set up, but you'll never have to worry about it again.
Ben
Old 12-28-2003, 06:46 AM
Default Re: Clearance probs with oilpressure sending unti after Endyne catch can install . Help (Bnjmn)
well i never worried about it until now that i hooked this catch can up. i guess illtry that then , i have allthe extra fittings and lines todo it that way. how did you mount it to the firewall ? just zip tie it to something ?
DannyDeuce
05-02-2006 01:51 PM
frostbite21
04-17-2006 10:28 PM
StylishDOHC
04-04-2006 09:02 PM
Scary1109
12-03-2002 03:55 PM
Xerxes
01-16-2002 06:53 PM
Quick Reply: Clearance probs with oilpressure sending unti after Endyne catch can install . Help
