New build but getting distracted
Old Aug 13, 2004 | 03:46 PM
calib17a's Avatar
Default New build but getting distracted
I've been investing in my new build and actually I'm close to completion.
New build consists of: 99 Ls shortblock resleeved with "new big sleeves" to 83mm by Benson Machine, step deck, Ls crank balanced and polished, Manley turbo tuff rods, CP 83mm 9:1 pistons, ACL Bearings, AEBS main studs and head studs, assembled by no other than Dan Benson himself, Fluidampr harmonic dampener (thanks to Arturbo!) , new remote oil filter setup, new oil filter setup, Endyne catch can setup, b17a head by Rick Kemp (first owner of Portflow, recommended by Dan Benson) p & p, special radius and angles on valve seats, Supertech coated valves, Eibach springs, CTR intake camshaft, Gsr exhaust camshaft, new exhaust setup consists of 3" kteller vbanded in 5 places with Borla ss 3" exhaust and carsound 3" cat
Benson sleeved and assembled ls block with "new big sleeves":
Toyosupr T4 equal length manifold on T4 GT35R w/ vband
New oil filter setup:
Engine bay with old Golden Eagle block:
I'm just waiting for the head to be finished but my attention has been going towards my new baby:
I've already changed the stock exhaust to 3" Blitz Nur spec touring catback exhaust, installed MBC, Blitz DCII boost guage.
Old Aug 13, 2004 | 03:51 PM
m R g S r's Avatar
Default Re: New build but getting distracted (calib17a)
Nicee. I would love to get a set of benson's for my block . . .
Old Aug 13, 2004 | 03:53 PM
System-7's Avatar
good luck with that new baby. You can't add a thing to the STI without it giving you a problem. Been working my friend's STI. He put a Booster controller and it would spike. turns out that he will need to get another turbo because the stock one needs to be ported or replaced in order to controll the boost. then we put a delete pipe with not cat, give me varied boost in different gears. he changed his intercooler to a Perrins brand front mount and he can't get full boost in 3rd gear. so goodluck. i'ld just leave it stock.
White Smoke's Avatar
i my honda
Global Mod
Looks good man
Wish it were mine What is your HP goal?
On a side note, you should get the new red defi BF's for your sti
It would be sooo fuxxing pimp. I cant wait till I get mine in
Old Aug 13, 2004 | 03:56 PM
Rod.'s Avatar
Default Re: New build but getting distracted (m R g S r)
We have the same setup for blocks . How many toys do you have? I can see a black teg also
Old Aug 13, 2004 | 04:00 PM
mEr's Avatar
mEr
Default Re: (System-7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by System-7 &raquo;</TD></TR><TR><TD CLASS="quote">good luck with that new baby. You can't add a thing to the STI without it giving you a problem. Been working my friend's STI. He put a Booster controller and it would spike. turns out that he will need to get another turbo because the stock one needs to be ported or replaced in order to controll the boost. then we put a delete pipe with not cat, give me varied boost in different gears. he changed his intercooler to a Perrins brand front mount and he can't get full boost in 3rd gear. so goodluck. i'ld just leave it stock. </TD></TR></TABLE>
i am going to have to disagree on that one...i have seen many STI's that just have a boost contoller and upped the boost and they run like champs..
Old Aug 13, 2004 | 04:13 PM
flip1199's Avatar
Default Re: (R...)
just curious what happened to your previous GE block?
Old Aug 13, 2004 | 04:29 PM
calib17a's Avatar
Default Re: (flip1199)
started to overheat from gasket not sealing, got to pull it and have Dan Benson check it out.
DC Love
Jun 23, 2010 01:48 AM
AViciousTHRUST
Feb 13, 2006 06:07 PM
KiNG $h!t
Sep 18, 2003 07:18 PM
synergy004
Jan 29, 2003 10:14 PM
synergy004
Dec 18, 2002 01:41 AM
