Differences between b-series heads.
Old Aug 15, 2004 | 12:43 PM
wantboost's Avatar
Who is Mr Robot?
Default Differences between b-series heads.
I need a b-series head to fab up a turbo manifold. Its going in a 99si. Now, i found a b18a1 head, is it really all that different from the b16a head in terms of port height and overall height? will it work to fab up the manifold and d/p?
Old Aug 15, 2004 | 12:54 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Differences between b-series heads. (wantboost)
someone has to know, come on, easy quest here
Old Aug 15, 2004 | 12:59 PM
Trak_Day's Avatar
New User
I will have my buddy pull up the flow charts he has... I believe the b16a head flows the best of the bseries if i am not mistaken.
Old Aug 15, 2004 | 03:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Trak_Day)
Thats not what i need to know, i just need to know if, externally, the two heads are the same on the exhaust side, im not running this head, its just for mock up.
Old Aug 15, 2004 | 03:28 PM
R THIS's Avatar
Default Re: (wantboost)
yes.. the exhaust sides are all the same.... its the intake side that changes depending on the head
Old Aug 15, 2004 | 03:29 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (R THIS)
ok, thanks, thats all i needed to know
Old Aug 15, 2004 | 05:12 PM
Adriano's Avatar
You have a 99 si with the b16a2 motor/doch vtec. The b18a1 is the worst b-series head and it's not even a vtec head. The best stock head is the type r witch is the same head as the b16 but with different cams/internals. I would just keep you stock head and upgrade the internals if you really need it too.
Old Aug 15, 2004 | 05:23 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (brryder)
I'm not running the b18 head, it is strictly for manifold mock up and fabrication, it will spend its life sitting on a block on a motor stand. I happen to like vtec and will kill to keep it
Old Aug 16, 2004 | 06:57 AM
Adriano's Avatar
sorry, for some reason i understood that you wanted to put it in. Yes, the b18a1 head has the same exhaust flange as you 99 si.
chriskuipers
May 8, 2007 07:46 PM
DSLHONDA
Oct 30, 2004 09:57 AM
Andre
Oct 13, 2003 12:48 AM
Lsos
Sep 10, 2003 08:49 PM
