Help WIth 3 Bar Map Sensor!?!?
Old Aug 12, 2004 | 08:12 PM
Turbocoupe97's Avatar
Default Help WIth 3 Bar Map Sensor!?!?
ok now i purchased one and i read hondata on how to install it but whn they said i have to use a rom editor to change the sensor type, is there anyway around it? or what? let me know, if not i dont got one of those things give me some insight???
Old Aug 28, 2004 | 05:04 AM
TurboIntegraGSR's Avatar
Default Re: Help WIth 3 Bar Map Sensor!?!? (Turbocoupe97)
Are you running a Hondata ECU? This is prob obvious, but you didnt mention. If so, maybe there is someone in your area with the ROM editor, if not contact Hondata, maybe you could overnite your ecu to them or a vendor for the upgrade....
Old Aug 28, 2004 | 05:33 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocoupe97 &raquo;</TD></TR><TR><TD CLASS="quote">ok now i purchased one and i read hondata on how to install it but whn they said i have to use a rom editor to change the sensor type, is there anyway around it? or what? let me know, if not i dont got one of those things give me some insight???</TD></TR></TABLE>
any type of management hondata aem uber ect needs to have the map rescaled for the new sensor.
email me if you need any help.
Old Aug 28, 2004 | 05:38 PM
m R g S r's Avatar
Default Re: Help WIth 3 Bar Map Sensor!?!? (b18cls1)
Does the chip need to be re-tuned when you swap sensors?
Old Aug 28, 2004 | 05:47 PM
b18cls1's Avatar
Default Re: Help WIth 3 Bar Map Sensor!?!? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Does the chip need to be re-tuned when you swap sensors?</TD></TR></TABLE>
some ecus interpolate the cells in the map when you rescale for the map sensor but in short it will not run the exacxt same because now you resolution of your map has decreased,
ie where you had 29 in hg ---&gt; 11psi in say 16 cells now you have 29in hg ---&gt;29 psi in the same 16 cells now the increments are broader from cell to cell.
Todallybuilt
Engine Management and Tuning
Oct 15, 2017 06:18 AM
Freshdot
Mar 13, 2011 03:23 PM
Turbocoupe97
Aug 13, 2004 06:52 AM
oemDC2
Jan 5, 2004 09:45 AM
