SuperCharger or Turbo for b18
I'm droppin' a b18 into my 2000 civic coupe. A question that passed my mind was which forced induction should I use. Mind U, this is going to be a daily driver. Thanks
Re: (Sketch_hs)
And which company should I go with? I heard that Greddy makes a lot of good quality street legal ish. Thanks 4 the tips
Re: (EJspoon)
put together your own turbo kit,yull get better stuff for less or about the same amount.after buying a kit,most likely you will want better or different parts,so you will end up spending more in the long run.screw street legal...you are already droppin in a different motor...street legal=slow.good luck
Re: SuperCharger or Turbo for b18 (EJspoon)
Welcome to the turbo world. Supercharger, Wots that?
If you have a little knowledge about turbos and know what parts you need then I suggest a custom turbo but if you don't know what your looking for and can't be bothered to do a little research and just want simplicity, go for an off the shelf turbo kit.
