what is the best method for tracking down an ehaust leak
Old Aug 15, 2004 | 03:41 PM
fipracing_com's Avatar
Default what is the best method for tracking down an ehaust leak
i have an exhaust leak and cant seem to find the exact source, anybody got some tricks to tracking it down? This is a new install so thier is no TELL tail signs of carbon deposits. All bolts are tighted, it is just really hard to tell where the leak is.
Old Aug 15, 2004 | 03:50 PM
stinker504's Avatar
I used a torch. You put the flame near any area that might have a leak and it'll flicker if you do. Of course you must have the engine on
Old Aug 15, 2004 | 03:55 PM
torr's Avatar
Default Re: (stinker504)
i use soap and water. let the car run, use a spray bottle filled with saopy water and start spraying, look for bubbles.
Old Aug 15, 2004 | 04:03 PM
Default Re: (torr)
great thanks... i will try the soap and water.
Old Aug 15, 2004 | 04:16 PM
honda9369's Avatar
Default Re: (fipracing_com)
dude just jack up your car alittle turn your car on and hold your hand near all the connection. u can feel the air. just dont burn yourself
Old Aug 15, 2004 | 04:18 PM
honda9369's Avatar
Default Re: (honda9369)
its probaly comin from 1 of your donut gaskets. there known to leak untill they mold into place.
Old Aug 15, 2004 | 04:22 PM
my leak is somewhere on either the turbo mainfold to the head, turbo to manifold or turbo to DP.
Old Aug 15, 2004 | 04:48 PM
Chris F's Avatar
Stick a vacuum line in brake fluid. Wherever the smoke comes from, that's your exhaust leak.
Don't ask me how I know
-Chris
Old Aug 15, 2004 | 06:55 PM
pip9's Avatar
Default Re: (ccfries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">Stick a vacuum line in brake fluid. Wherever the smoke comes from, that's your exhaust leak.
-Chris</TD></TR></TABLE>
I've always used trans fluid not brake fluid and it worked very well. Just dont use too much maybe a cap full or two.
Old Aug 15, 2004 | 08:12 PM
fbp-em1's Avatar
Default Re: (pip9)
yea trans fluid is a good detergent and will help clean and fix stuck valves, check your wastegate to manifold connection i recently had a leak there and it was annyoning.
cmc600rr
Apr 11, 2010 11:21 AM
Cooch2005
Sep 28, 2005 09:14 AM
hbracer93
10
Jul 27, 2005 01:04 PM
stoopid_monkey
May 17, 2005 11:19 AM
asianspeed
Feb 27, 2003 06:25 PM
